173
OxygenOS 4.5.13 OTA for the OnePlus 5
  1. sachetrao98
    Cupcake Oct 25, 2017
    Guillo_von_Büren likes this.
  2. Praveen3242
    Froyo Oct 25, 2017
    Praveen3242 , Oct 25, 2017 :
    battery time not good draining very fast... now am on ship so mostly dont use phone as usual i use but after that need to charge once a day... phone is mostly idle after that battery draining itself. if i use from charge i don't think it could make half of day...
  3. AdrianoH93
    AdrianoH93 , Oct 25, 2017 :
    I found this print with today's date and time. with a supposed new update. it's real?
  4. Shirish_Babbur
    Gingerbread Oct 25, 2017
  5. Cervantes
    Moderator Moderator Oct 25, 2017
    Cervantes , Oct 25, 2017 :
    Thread merged
    read first post
    this is the last update
    otto2 likes this.
  6. pscheffers
    pscheffers , Oct 25, 2017 :
    Download the older rom 4.5.10 from: http://downloads.oneplus.net/oneplus-5/oneplus_5_oxygenos_4.5.10/
    Copy it on to your device via USB cable. (it must be in the ROOT folder)
    Then go to: Settings - System Updates
    Click the Gear Icon in the top right hand corner
    Turn off auto-download over wifi (otherwise 4.5.13 will autodownload back to your device after the downgrade)
    then click: Local upgrade (you should see the downloaded file there )
    click the file and the downgrade should begin
  7. 9478441880
    Froyo Oct 25, 2017
    9478441880 , Oct 25, 2017 :
    me too downgrade to 4.5.10
  8. Hacky0992
    Froyo Oct 25, 2017
  9. Manas_Mishra_1989
    Ice Cream Sandwich Oct 25, 2017
    Manas_Mishra_1989 , Oct 25, 2017 :
    Downgrade to 4.5.10 or just use mobile data and not WiFi. The update has messed up wifi idle battery drain.
    I first downgraded to 4.5.10 and after i found the issue i again upgraded and tried to remain on 4G data and did not find battery drain even on 4.5.13
    Remember to wipe cache from recovery after each update or downgrade
  10. S1508947446044
    S1508947446044 , Oct 25, 2017 :
    I am getting Signature Validation Error at 5% as some guy mentioned above. I have wiped the cache from Storage and Memory also deleted the cache and data from System Update app, also factory reset, but still getting Signature Validation Error.
    Help please
  11. Sreenivasan_Appu
    Sreenivasan_Appu , Oct 25, 2017 :
    I have tried as per advise, but still I am facing the same issue. please look into this and fix this up earliest convenience.
    thanks
    Sreeni
  12. varma246
    Lollipop Oct 25, 2017
    varma246 , Oct 25, 2017 :
    Ok!!,then Download oxygen updater app from playstore and follow the instructions of app to download and install the update.
  13. JnManso
    Eclair Oct 25, 2017
  14. Arnab2297
    Arnab2297 , Oct 25, 2017 :
    Will it wipe the device? Personal data and all.
  15. Bullo Oka
    Honeycomb Oct 25, 2017
    Bullo Oka , Oct 25, 2017 :
    One plus, why don't you try to copy the camera features & functions of Honor 8 pro, instead of those boring iphone devices.
    you need lots loooots of work in camera department.
  16. GuitarBart
    Jelly Bean Oct 25, 2017
    GuitarBart , Oct 25, 2017 :
    You know it's completely useless to post this here? This is a community thread about an update...
    Deactivated User and Bullo Oka like this.
  17. Bullo Oka
    yep, I know... i was just pissed after watching the honor 8 pro in depth cam review.
    GuitarHero0179 likes this.
  18. GuitarBart
    All right. I totally agree they can improve on the camera
    Bullo Oka likes this.
  19. Vundurty
    Vundurty , Oct 25, 2017 :
    After installing the new update, I found my phone heating up for any task like playing games, watching a video, while charging the battery, etc. Even my battery dries up soon when the phone is in idle state.
    I didn't had any of such issues in the previous version.
  20. Dr.Che
    Eclair Oct 25, 2017
    Dr.Che , Oct 25, 2017 :
    hey, i haven't updated from 4.5.10 to the latest one what u guys suggest should i or shouldn't??
