173
OxygenOS 4.5.13 OTA for the OnePlus 5
  1. arunasc
    Cupcake Oct 27, 2017
    arunasc , Oct 27, 2017 :
    Update doesn't fixed 2 issues:
    1. "Optimized adaptive brightness" - autobrightness isn't working we'll as previous - to dark in dark enviroments (can't normally use phone while walking down the street in the evening - screen brightness jumping as crazy - to very very low (cant see screen) - to normal)
    2. GPS - issues with GPS - long start (hight accurracy location turned on), losing signal while driving, sometimes inaccurate - shows that i'm driving near the road (offroad).
  2. LAKSHMI NARAYANAN A
    Eclair Oct 27, 2017
    GOPALA KRISHNAN A likes this.
  3. 88dwanel
    88dwanel , Oct 27, 2017 :
    the only problem I am having,is the adaptive display is a bit on the haywire side, on 4.5.12 it's kinda stable but at current 13 version is Lina patchy
    solve that.
  4. kleinstadtbube
    Ice Cream Sandwich Oct 27, 2017
    kleinstadtbube , Oct 27, 2017 :
    Did you clear cache in recovery?
  5. mastpavi
    mastpavi , Oct 27, 2017 :
    Hi guys,
    After latest update 4.5.13 i am facing issue that i am not able to install any .apk file in my mobile.
    When its come to stage Install or Cancel page, the Install button is not working, i m not abt to go further on that, only Cancel button is working.
    I think Install button is decibel...
    Any solution for this?
  6. pscheffers
    pscheffers , Oct 27, 2017 :
    No it will not!
  7. El-Hodgy-79
    El-Hodgy-79 , Oct 27, 2017 :
    the update is in but the youtube audio lag has gotten worse instead of better?! what to do?
  8. Axel22
  9. F_Siddhant_Wahane_uuWf
    Gingerbread Oct 27, 2017
    F_Siddhant_Wahane_uuWf , Oct 27, 2017 :
    Don't install any apps! Then why the hell i bought this phone! And the camera focus actually downgraded as before it used to take much clear photos! Also i keep my phone very clean with no unwanted apps, so don't act like you know everything, be smart just don't over do it!!!
  10. Anurag_Das_51
    Froyo Oct 27, 2017
  11. fidus62
    Jelly Bean Oct 27, 2017
    fidus62 , Oct 27, 2017 :
    That knows only Mr Chi Pi and he will say nothing...
  12. Anurag_Das_51
    Froyo Oct 27, 2017
    Anurag_Das_51 , Oct 27, 2017 :
    [e]1f602[/e][e]1f602[/e]
  13. El-Hodgy-79
    I forgot to mention it happens linked to a bluetooth device, audio set up
  14. Aashish Bhatia
    Eclair Oct 27, 2017
    kleinstadtbube likes this.
  15. otto2
    Photography Expert Oct 27, 2017
    otto2 , Oct 27, 2017 :
    You re a clever one. Do not install any app for checking, if it 's the System draining or an app.... Got it now?
  16. Deactivated User
    Oct 27, 2017
    otto2, Uncle timmy, MikeG247 and 2 others like this.
  17. F_Siddhant_Wahane_uuWf
    Yes
    otto2 likes this.
  18. F_Siddhant_Wahane_uuWf
    Who asked you? And even if i don’t have as good intellect as you, but still paid 33k so i have all the right to ask for better upgrades even if some smartas§ like you think it's spoon feeding! Pity how a person with your intellect have so much time to come down to to argue with me the so called low intellect
  19. kleinstadtbube
    Well. Then the easy trouble shoot steps given for your battery drain should be no problem at all for you.
    In my case the last update was very good. No drain no problems. Every update for me was good.
    If you would do bug reports and describe you problems better or send them to support, maybe
    your updates are getting better for you. Sure it's the update? Not an app update?
    Why cause it didn't happen before the update? See. So many questions.
    Problems with cam due to an update where nothing on the cam was changed? Well. OK.
  20. MikeG247
    MikeG247 , Oct 27, 2017 :
    Nobody wants to argue with you on here. You asked for help and you were given good solid advice. You chose to respond with a cheeky, smart-assed rebuke just as you have again. You people are getting yourselves a very bad name on this forum, and deservedly so.
