173
OxygenOS 4.5.13 OTA for the OnePlus 5
  1. kuruba sreedevi
    Cupcake Oct 15, 2017
  2. kleinstadtbube
    Ice Cream Sandwich Oct 15, 2017
    kleinstadtbube , Oct 15, 2017 :
    It's because the roll out is in stages.
    4.5.11 and 4.5.12 have been withdrawn.
    So you have to wait. Or if you can't:
    - You can use Oxygen Updater
    - You can use the VPN method
    - You can flash the zip file
  3. Deactivated User
    Oct 15, 2017
    otto2 and kleinstadtbube like this.
  4. MikeG247
    Jelly Bean Oct 15, 2017
    MikeG247 , Oct 15, 2017 :
    Ignore them chum. They don't deserve an answer.
    otto2 and Deactivated User like this.
  5. TonioLA
    TonioLA , Oct 15, 2017 :
    What does Google acc means? Something related to GPS?
  6. kleinstadtbube
    Google Acc is Google Account.
    The email you need to run any Android device.
    If you mean Google Play Service with GPS yes.
    If you mean the GPS signal itself no.
    MikeG247 and otto2 like this.
  7. Luis Sismeiro
    Honeycomb Oct 15, 2017
    Luis Sismeiro , Oct 15, 2017 :
    Unfortunately I don't receive anything from OnePlus but I gladly accept the OnePlus 6 for testing.
  8. Suraj gurav 007
    Suraj gurav 007 , Oct 15, 2017 :
    i dont know any thing..
    one plus is too slow to give updates..
    if u want to know...tweet or call customer care
    shriman_shubham_g likes this.
  9. Suraj gurav 007
    ohhh
  10. meetamit7
  11. kleinstadtbube
    Sure. For the very first time I answer this question.
    You can use Oxygen Updater from the market.
    Or use VPN software and set to Germany or Canada.
    Or you flash the zip file.
    If you don't want to use one of these methods wait as update is rolled out in stages.
  12. G_Gareth_Morgan_yBpB
    Froyo Oct 15, 2017
  13. p09
    Donut Oct 15, 2017
    p09 , Oct 15, 2017 :
    some1 more sensible and gentle than how u respond, think about it, u can ignore mssgs which u dont like rather than insulting some1, anyways i dont wanna stoop as low as u, have a better day
  14. otto2
    Photography Expert Oct 15, 2017
    otto2 , Oct 15, 2017 :
    Download it, install it, Judge by yourself. Do you really think, anyone here has the same setup as you and can tell you??? BTW battery draining is mostly caused by a bad app or wrong setup /usage of your phone.
    MikeG247 likes this.
  15. F_Palanisamy_Rajeshkumar
    F_Palanisamy_Rajeshkumar , Oct 15, 2017 :
    use VPN to connect through canada or Germany
  16. Alex Soriano Serbosa
    Alex Soriano Serbosa , Oct 15, 2017 :
    Happens to same to me. I'm from Catalonia
  17. G_Gareth_Morgan_yBpB
    Froyo Oct 15, 2017
    G_Gareth_Morgan_yBpB , Oct 15, 2017 :
    Thanks for your nonsensical answer. I'm fully aware of what can cause a battery drain, my question was about firmware update, as I experienced issues on the .11 update with a excessive battery drain.
  18. SLAVA_Kyiv
    SLAVA_Kyiv , Oct 15, 2017 :
    Hi, all!
    Jimmy Z, do you have a patch for update from 4.5.12 to 4.5.13 ?
    Best regards,
  19. Srifz25
    Donut Oct 15, 2017
    Srifz25 , Oct 15, 2017 :
    I didn't get any update new..still on 4.5.10 and says system upto date..is there any reason behind it?
  20. zoarquenix
    Froyo Oct 15, 2017
