280
OxygenOS 4.5.7 OTA for OnePlus 5
Thread Status:
Not open for further replies.
  1. Juanjesusabreusantana
    Donut Aug 2, 2017
  2. dthx
    Eclair Aug 2, 2017
    dthx , Aug 2, 2017 :
    I also had battery issues right after the previous updates with Google Play Services and Android system eating most of the resources. In all cases, wiping the cache (in recovery mode) solved the issue. You won't lose any data and the next day, the battery drain issue is over. This version gives me the best standby drain so far.
    Plalande33 and JoseMoraM like this.
  3. G_Vishal_Gupta_BNuJ
    Gingerbread Aug 2, 2017
  4. JodeMaartel
    JodeMaartel , Aug 2, 2017 :
    Just updated since a few hours, I've to wait to see...
    I agree.
    After each update: clearing app cache via settings/memory, and system cache via recovery.
    fhavas likes this.
  5. Jesus Lazcano
    Ice Cream Sandwich Aug 2, 2017
  6. kylosillver
    Froyo Aug 2, 2017
    kylosillver , Aug 2, 2017 :
    mine got worse on 5ghz band getting really low range it was pretty good on last update 4.5.6
  7. drewfaas
    Froyo Aug 2, 2017
    drewfaas , Aug 2, 2017 :
    I'm noticing a slight improvement in battery life and a bit smoother performance all around. 4K video performance is the big winner here. If you want to smoothen performance and improve battery life even more check out the thread here on enabling developer options.
    This handset just keeps getting better and better for me!
    SergiuszJasper likes this.
  8. shriman_shubham_g
    Froyo Aug 2, 2017
    asish.pikun likes this.
  9. dragoscorodeanu
    dragoscorodeanu , Aug 2, 2017 :
    Thank you, dear sir! I followed your steps and in an instant the update was available! And I think I will keep opera VPN, I think it will be quite handy.
  10. ayankm
    Eclair Aug 2, 2017
    ayankm , Aug 2, 2017 :
    I went back to 4.5.5 and now updated to 4.5.6 incremental. Battery seems much better in the last one hour of use. One more issue on 4.5.7 was standby battery use. 9-10% straight down in 8hrs.
    I will follow the app cache clean via settings the next time. I did clean the cache through recovery after install.
  11. F_Nitesh_Kunwar_zlHB
    Froyo Aug 2, 2017
  12. G_Jannick_Vervoorn_udYv
    Honeycomb Aug 2, 2017
    G_Jannick_Vervoorn_udYv , Aug 2, 2017 :
    didnt received in the Netherlands to. Just download opera VPN with the viking head! and turn your VPN on germany. than you Will recieve the update. after installed Just turn it off and your good to go! your question is it normal?
    yes it is because they always enroll the update slowly around the world!
  13. smith.pranjul
    akunh121 likes this.
  14. felipemendes
    Jelly Bean Aug 2, 2017
    felipemendes , Aug 2, 2017 :
    Just as a reminder, one can also update by downloading the OTA file, saving on the root of /sdcard, then going to the System Updates page, clicking on the gear, and finally on "local upgrade".
  15. Stanley08
    Stanley08 , Aug 2, 2017 :
    Not for me.
    Does this answer your question? Lol.
  16. gha2012
  17. daddycool
    daddycool , Aug 2, 2017 :
    yes battery is better for me. for me it's like the same I was getting on 4.5.3. I am happy [e]263a[/e]️
  18. dying_osiris
    dying_osiris , Aug 2, 2017 :
    The brightness level in a dark room is yet too uncomfortable. It really strains the eye. The lowest setting off auto brightness in OP3/3T was great. This should really be fixed
  19. G_Mister_thakur_WmDP
  20. G_Mister_thakur_WmDP
    G_Mister_thakur_WmDP , Aug 2, 2017 :
    nope
