263
OxygenOS 4.7.6 OTA for the OnePlus 5T
Thread Status:
Not open for further replies.
  1. X1513120527688
    Froyo Dec 28, 2017
    X1513120527688 , Dec 28, 2017 :
    yeah it's worked great for me I just made sure I cleaned cache after the update.
  2. Gurupranesh
    Eclair Dec 28, 2017
    Gurupranesh , Dec 28, 2017 :
    Great! Thank you. I will Take your word for it and upgrade using VPN(CANADA)
  3. gauravnema
    Honeycomb Dec 28, 2017
    gauravnema , Dec 28, 2017 :
  4. X1513120527688
    Froyo Dec 28, 2017
  5. Gurupranesh
    Eclair Dec 28, 2017
  6. X1513120527688
    Froyo Dec 28, 2017
    ok let me know how you get on. I used the app to download the update the went to update in setting and used update from local upgrade.I would imagine as I'm not rooted and on stock recovery it would not install if it had been tampered with. I would just clean cache from recovery after update to be Safe. Hope everything goes well [e]1f44d[/e]
  7. xeon101
    Ice Cream Sandwich Dec 28, 2017
    xeon101 , Dec 28, 2017 :
    wow.... superbly done OnePlus....got it.... didn't make mistakes taking the OnePlus 5t afterall.
  8. CvTran
    Cupcake Dec 28, 2017
    CvTran , Dec 28, 2017 :
    Dear 1+ , just updated to 4.7.6. Very confused, I was able to unlock the phone with just one eye opened. My face was covered. Should we be concerned?
  9. Jeremias.uecker
    Eclair Dec 28, 2017
  10. CvTran
    Yes, under face unlock menu options
  11. Jeremias.uecker
    Eclair Dec 28, 2017
  12. CvTran
    Can you try to unlock the phone while covering your face and just open one eye?
  13. Jeremias.uecker
    Eclair Dec 28, 2017
    Jeremias.uecker , Dec 28, 2017 :
    Yes, of course. So when you close one eyes, everything works fine. By the way, thanks for the tip xD. but if you hold it with your hand he doesn't recognize the face. No matter whether it is much or little concealed.
  14. erik2282
    Gingerbread Dec 28, 2017
    erik2282 , Dec 28, 2017 :
    I was on 4.7.4. Used opera VPN through Canada, and updated to 4.7.6. skipped 4.7.5. all seems to be running fine
  15. G_Rey_King_Sharif_xlHd
    G_Rey_King_Sharif_xlHd , Dec 28, 2017 :
    Added assistive lighting for face unlock
    works really well !! really great! even when it gets it to work when you raise the screen and open it. where could I put this development idea?
  16. CvTran
    I cover my face with my hand and only show one eye. It still unlock the phone most of the time.
  17. Jeremias.uecker
    Eclair Dec 28, 2017
    oh well. whats going on? A friend would have to add the face new after an update. Maybe this will help, because there is too little information of your face stored at the moment.
  18. Carfs
    Froyo Dec 28, 2017
    Carfs , Dec 28, 2017 :
    VPN Germany ;-)
  19. polisettysd
    polisettysd , Dec 28, 2017 :
    Yes it's available for all but it takes time... Probably a few days.
    But if u want it as soon as the update is available then download the app shown in the image attached and follow the instructions in the app u will have that update in no time.
  20. Deactivated User
    Dec 28, 2017
