263
OxygenOS 4.7.6 OTA for the OnePlus 5T
Thread Status:
Not open for further replies.
  1. Ph3NoM
    Honeycomb Jan 4, 2018
    Ph3NoM , Jan 4, 2018 :
    Not working :-/
  2. NarendrenD
    Cupcake Jan 4, 2018
  3. Paul_W_
  4. N1514262230662
    Cupcake Jan 4, 2018
  5. G_Justin_Gindin_zONf
    Froyo Jan 4, 2018
    G_Justin_Gindin_zONf , Jan 4, 2018 :
    Question... when you skip an update, like 4.7.4 for instance, and install 4.7.6, does 4.7.6 also include system updates from the previous? I.E... if something is fixed in 4.7.4, and you skip it, will the fix carry over into the 4.7.6 update?
    I thought someone mentioned that the stock SMS app for these phones allowed group messaging after an update. Mine still wont after 4.7.6. Maybe I misread something? I like using the google messaging app, but it doesnt show an icon on the ambient screen, which is annoying.
  6. Sun90
    Starting Point Expert Community Expert Jan 4, 2018
    Sun90 , Jan 4, 2018 :
    A fix in a previous version would obviously be carried over to the next version as there won't be any code changes to that.
  7. F_Siddharth_Rajvanshi_FR
    Cupcake Jan 4, 2018
  8. G_Justin_Gindin_zONf
    Froyo Jan 4, 2018
    I wasnt sure if the update carried all of the information for all previous updates. Since the size seems to change depending what you are doing. OTA incremental update is smaller than the full download/flash update. This is what i was asking. Obviously if you apply an update, and there was a fix, that fix will remain in place for the next update. But I wasnt sure if you SKIP an update, if any fixes in that would be applied whenever you update again.
  9. Sun90
    OTA updates , especially the smaller zip size on will only carry the changes made over to the previous update .
    Hence if you skip update 1 with a fix and try to update 2 ,then that update to will have that fix .
    If you are still sceptical then go for the full rom zip file install instead of the smaller one.
  10. G_Justin_Gindin_zONf
    Froyo Jan 4, 2018
    Nope...I feel thats how it SHOULD work haha. I was just confirming. Ive never skipped an update before, but the 4.7.4 had such bad reviews I wouldnt do it.
    I just need to confirm if the group messaging was fixed in the stock SMS app or not. If not, then there is no issue. If it was fixed in 4.7.4, then I def didnt get that fix in 4.7.6.
    Thanks!
    Bluecat08 likes this.
  11. Paul_W_
    Paul_W_ , Jan 4, 2018 :
    This is the reason I upgraded to 4.7.4 when I heard 4.7.6 was being released
  12. JHannaman82
    Eclair Jan 4, 2018
    JHannaman82 , Jan 4, 2018 :
    US customer here. I've received the 4.7.6 OTA just a few hours ago. the rollout seems to be moving along.
  13. Neelakanta_Swamy_Kella
    Cupcake Jan 4, 2018
  14. sambit512
    Cupcake Jan 4, 2018
    sambit512 , Jan 4, 2018 :
    in which version are you talking about?
  15. aadarshmittal
    Froyo Jan 4, 2018
  16. deepak_patra
    Froyo Jan 4, 2018
    deepak_patra , Jan 4, 2018 :
    will not face any issue. don't worry
  17. deepak_patra
    Froyo Jan 4, 2018
    I am also having the same issue. can anyone pls guide here?
    Omar5T likes this.
  18. hbvishnu
    Froyo Jan 4, 2018
  19. rehman.ibad
    Froyo Jan 4, 2018
  20. deepak_patra
    Froyo Jan 4, 2018
    worked. Thanks a lot
