963
OxygenOS 5.0.1 OTA for the OnePlus 5
Thread Status:
Not open for further replies.
  1. flyingdad Ice Cream Sandwich Jan 10, 2018
    flyingdad, Jan 10, 2018 :
    Factory reset
    Denis303 likes this.
  2. Soviet_Pope Eclair Jan 10, 2018
    Soviet_Pope, Jan 10, 2018 :
    Well yes that works but it was easier and faster to have it that way
  3. flyingdad Ice Cream Sandwich Jan 10, 2018
    Some of the app that work. See your settings.
    Some of the apps which work. See your settings.
  4. MikeG247 Jelly Bean Jan 10, 2018
    MikeG247, Jan 10, 2018 :
    It depends on your point of view. Now WiFi etc can be enabled or disabled with a single tap, which personally I prefer. Feel free to state your preference for the old way using the feedback form (you will find the link in the opening post).
  5. drewkills Cupcake Jan 10, 2018
  6. chinka khandelwal Eclair Jan 10, 2018
    chinka khandelwal, Jan 10, 2018 :
    I've just updated to orea and till now I haven't faced any bug should I've to wipe cache?
  7. marcusskyfall Jelly Bean Jan 10, 2018
    MikeG247 likes this.
  8. MJK1314 Donut Jan 10, 2018
  9. MasterFee Cupcake Jan 10, 2018
    MasterFee, Jan 10, 2018 :
    Any chance it will work with TWRP by blu_spark (also found on XDA)?
  10. flyingdad Ice Cream Sandwich Jan 10, 2018
    As the British say: "If it ain't broke don't fix it". So, if everything works fine, OK, you could leave it so. But still, wipe cache is easy to do, no data are suppressed and it may prevent possible bugs.
  11. chinka khandelwal Eclair Jan 10, 2018
    Okay thanks for your help
  12. Asumos Ice Cream Sandwich Jan 10, 2018
    Asumos, Jan 10, 2018 :
    no I tried that first. but it did work to flash magisk after. but update script required codeworks twrp
  13. MasterFee Cupcake Jan 10, 2018
    So will bluspark most definitely NOT work? Which means I would have to flash codeworks twrp, update and then flash bluspark twrp if I want to keep bluspark?
  14. MasterFee Cupcake Jan 10, 2018
    So is switching to codeworks the better solution anyway?
  15. Asumos Ice Cream Sandwich Jan 10, 2018
    not sure, for me I keep original recovery installed and use
    fastboot boot recovery.img
    instead of
    fastboot flash recovery recovery.img
    just I flash whatever image happens to work
  16. omarhox Cupcake Jan 10, 2018
    omarhox, Jan 10, 2018 :
    hi
    thanx for this nice update
    i have some notes on it
    - buttons in the notification bar: in previous version of oxygen, i could push in the name of buttons and quick settings appear.
    but in new oxygen this feature is gone ,so bad.
    - i wish you add feature to video player that i can listen to voice only ,so the video play and mobile is locked.
    best wishes...
    omartaka
  17. boyar4eg Cupcake Jan 10, 2018
    boyar4eg, Jan 10, 2018 :
    After the update, the button on the headset stopped working. used the aimp player and played music at the click of a button. After the update, when you click the button, google music starts. why can not I set the default application?
  18. sai.arshanapalli Cupcake Jan 10, 2018
  19. Denis303 Gingerbread Jan 10, 2018
    Denis303, Jan 10, 2018 :
    Did you try to set aimp as default Player?
  20. boyar4eg Cupcake Jan 10, 2018
    yes, but it did not help, now it just does not work. everything was fine before the update
