963
OxygenOS 5.0.1 OTA for the OnePlus 5
Thread Status:
Not open for further replies.
  1. Oldx
    Gingerbread Dec 24, 2017
  2. miskobartanus
    Ice Cream Sandwich Dec 24, 2017
    Shaik Riyazali likes this.
  3. Dr Gireesh Likhyani
    Froyo Dec 24, 2017
    Dr Gireesh Likhyani , Dec 24, 2017 :
    no info about it yet
    the post of just for fun
    #sarcasm
  4. NaiyerAsif
  5. KP OnePlue
    KP OnePlue , Dec 24, 2017 :
    That's because you're seeing the icons on your Screen Saver, and the notifications on your Lock Screen. You can disable this on your screen saver under Display in Settings.
  6. shamseer_e_Sanju
    Froyo Dec 24, 2017
    Hydra Bob likes this.
  7. G_Ravish_Nandha_GPgd
    Donut Dec 24, 2017
  8. Hydra Bob
    Marshmallow Dec 24, 2017
    Hydra Bob , Dec 24, 2017 :
    Yes if you want to do things by the book then backup your data and do a clean install then restore your data to the phone. But you don't have to, it seems like a lot of people are just applying the update directly which shouldn't result in any data loss.
  9. raghav1011
    Cupcake Dec 24, 2017
    raghav1011 , Dec 24, 2017 :
    Download Opera vpn, select Germany [e]1f1e9_1f1ea[/e], download and enjoy, increment rollout hai
    India me time lagega
  10. Cervantes
    Lollipop Moderator Dec 24, 2017
    Cervantes , Dec 24, 2017 :
    Thread merged
    Read the firs post
  11. pranavgoinglive
    Froyo Dec 24, 2017
  12. the_reckoner
    the_reckoner , Dec 24, 2017 :
    Thats unlikely since their servers will be loaded with a ton of people pulling the OP5's Oreo. They might also be short staffed due to the holidays and wouldn't want bugs/complaints from 2 phones at the same time
  13. Hydra Bob
    Option 3 nothing wrong with your phone or OnePlus, it's your fault:p
    MikeG247 likes this.
  14. kavinash
    Eclair Dec 24, 2017
    kavinash , Dec 24, 2017 :
    it is there..... appeared once I cleared cache.....sorry for post...
  15. Ankit.d
  16. Aniket bhatia
    Eclair Dec 24, 2017
  17. Shailesh14ggb16
    Donut Dec 24, 2017
  18. gohar_nadeem
    Honeycomb Dec 24, 2017
    gohar_nadeem , Dec 24, 2017 :
    Download opera VPN and connect to Canada region and check for update.
  19. ssquare89
  20. gohar_nadeem
    Face unlock will be available in future updates.
