451
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. F_Thakur_Arun_Singh_Jada
    Donut Jan 4, 2018
  2. DarkSJ1998
    Honeycomb Jan 4, 2018
    DarkSJ1998 , Jan 4, 2018 :
    Yes you can, but do take backup of all your data, even internal storage. Because there are chances that you would have to do a factory reset once you upgrade to OxygenOS 5.0.1 as it's a really big update. :)
    Take backup of all your data & you may proceed to install the OTA ;)
  3. mahibmit
    Cupcake Jan 4, 2018
    mahibmit , Jan 4, 2018 :
    Thank you
  4. sushil3629
    Gingerbread Jan 4, 2018
    tnttrx likes this.
  5. frank_y
    Cupcake Jan 4, 2018
    frank_y , Jan 4, 2018 :
    After the latest update, I yet have much consumption of battery because of data connection on 4g.. What could be the reason?
  6. ghostofcain
    Marshmallow Jan 4, 2018
    ghostofcain , Jan 4, 2018 :
    That you've not long updated? All updates take a little while to settle give it at least 3-4 full charge cycles and then come back
    Sun90 likes this.
  7. Sun90
    Starting Point Expert Community Expert Jan 4, 2018
    Sun90 , Jan 4, 2018 :
    134mb is for OnePlus 3
    145mb is for OnePlus 3T.
  8. ghostofcain
    This very thread, by reading.
    Sun90 likes this.
  9. onepluseshaan
    onepluseshaan , Jan 4, 2018 :
    the update in back and this time there's no "harmful app" notification. It seems OnePlus has solved the problem. Cheers.
  10. Sun90
    It's Google who resolved the issue after oneplus reported to them about it.
  11. ghostofcain
    Nope, false positive was removed by Google.
    Abhi Dahiya, Sun90 and onepluseshaan like this.
  12. adarsh majhi
    Eclair Jan 4, 2018
  13. adarsh majhi
    Eclair Jan 4, 2018
    adarsh majhi , Jan 4, 2018 :
    Currently I'm on 4.5.1 and I'm getting around 3.30 hrs of SoT.
    So is the new update gonna improve the battery performance?
  14. Sun90
    It depends on the usage patterns / apps installed / the way phone is configured etc.
    And varies from one phone to another.
    Abhi Dahiya likes this.
  15. Sun90
    May be.
    Install it to know how it holds good for your usage.
  16. frank_y
    Cupcake Jan 4, 2018
    I did do abt 5 full charges meanwhile, so don't know. Did clean cache after the update also
  17. ghostofcain
    Have you tried the pinned battery threads? , lots of good advice and hints in them.
    Sun90 likes this.
  18. Sun90
    Try a factory reset and check.
    Do back up all important data before making the same.
  19. asingha94
    Donut Jan 4, 2018
  20. ghostofcain
