450
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. Srinivas_3T
    Froyo Jan 9, 2018
    Srinivas_3T , Jan 9, 2018 :
    first is the charger working fine, battery up time normal?
    how long full charge lasts?
    check Facebook or other battery extensive apps if Ny force close them
    check for screen lock duration.
  2. Wizardiguy
    Cupcake Jan 9, 2018
    Wizardiguy , Jan 9, 2018 :
    if you don't get the OTA directly, you can download the update downloading the file in the download page of one plus. follow the instructions and you will be fine. I already did it twice.
  3. Bobbie63
    Nougat Jan 9, 2018
    Bobbie63 , Jan 9, 2018 :
    If it would be there, that could be an option, but it isn't.
    ghostofcain and Wizardiguy like this.
  4. Wizardiguy
    Cupcake Jan 9, 2018
  5. Bobbie63
    Nougat Jan 9, 2018
    Wizardiguy likes this.
  6. Wizardiguy
    Cupcake Jan 9, 2018
    I agree they are beta, but I've been using the latest and in fact the open beta is more stable than 5.0, specially with parallel apps.
  7. Bobbie63
    Nougat Jan 9, 2018
    Yes, but this thread is about the new update OOS 5.0.1 which isn't on the support site yet.
  8. Wizardiguy
    Cupcake Jan 9, 2018
    aaahh, sorry hehe. I am still waiting for the patches for Spectre and Meltdown. That would be great.
    Bobbie63 likes this.
  9. Bobbie63
    Nougat Jan 9, 2018
    Well, guess it still could take some time before those come.
  10. E1515531637635
    Donut Jan 9, 2018
  11. Yannis Neris
    Ice Cream Sandwich Jan 9, 2018
    Yannis Neris , Jan 9, 2018 :
    Correct....
  12. ghostofcain
    Marshmallow Jan 9, 2018
    ghostofcain , Jan 9, 2018 :
    Yes 5.0. Can be downloaded from OnePlus website or full rom zip of 5.0.1 from this very site or of course VPN. These are all available for anyone not just Indians.
    Deactivated User likes this.
  13. Deactivated User
    Jan 9, 2018
    ghostofcain likes this.
  14. fdroko
    Jelly Bean Jan 9, 2018
    fdroko , Jan 9, 2018 :
    Oneplus will not have more support in India, buy an iPhone X
  15. Volvicice
    Gingerbread Jan 9, 2018
    Volvicice , Jan 9, 2018 :
    Hello just wanted to ask is anyone experiencing a slow down In the operation system? As some apps take a while to launch I wish I never updated now [e]1f623[/e]
    bharath818 likes this.
  16. ghostofcain
    You've tried a factory reset?, does it affect all apps or just certain ones?
  17. Volvicice
    Sorry forgot to mention I am using Oneplus 5 and the app I used was 360 battery usually loads fast and kills over heated apps but it's now slow and sluggish
  18. ghostofcain
    Sorry this is an OP3 (T) thread, if it's only the one app you might be better off consulting the app developer.
    Volvicice likes this.
  19. Subhrakant Badajena
    Donut Jan 9, 2018
    Subhrakant Badajena , Jan 9, 2018 :
    Just use VPN MASTER app (developer- MASTER VPN) FROM PLAYSTORE and use Germany or else Hong Kong in that. U can get that and install as well. I did that way
  20. ssharath
    Gingerbread Jan 10, 2018
