451
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. Sun90
    Starting Point Expert Jan 18, 2018
  2. Deactivated User
    Jan 18, 2018
    lkosova likes this.
  3. Bobbie63
    Marshmallow Jan 18, 2018
    VaibhavBhargava and Sun90 like this.
  4. Hydra Bob
    Hydra Bob , Jan 18, 2018 :
    It looks like NFS tried to post a notification but didn't assign it a proper channel for some reason. Contact the developer of the app there's not much OnePlus can do about that. And could you maybe put a shirt on lol?
    Sun90 and Vedang upadhye like this.
  5. lpadvisor
    Froyo Jan 18, 2018
    lpadvisor , Jan 18, 2018 :
    You could try to use Vellis Auto Brightness. It is very adjustable for brightness at different light levels. However I wasn't able to keep it running in Oreo. It works great in Nougat.
  6. lpadvisor
    Froyo Jan 18, 2018
    I had this problem in OOS 5.0.0. I rolled back to Nougat because of it. Is this not fixed yet? Will not upgrade until this is fixed.
  7. F_Jorden_Grewal_QmtA
    Ice Cream Sandwich Jan 18, 2018
    F_Jorden_Grewal_QmtA , Jan 18, 2018 :
    I don't think @OnePlus is planning to fix it. it's been a while I think they did this so ppl buy new stuff
  8. Deactivated User
    Jan 18, 2018
    lkosova, Hydra Bob and Bobbie63 like this.
  9. tpati
    Gingerbread Jan 18, 2018
    tpati , Jan 18, 2018 :
    I'm the only one when clear cache (settings/storage/cache/clear cache) always stays on 4.30MB instead on 0MB? Small thing but on last OSS nougat this number goes always to zero
  10. Deactivated User
    Jan 18, 2018
    lkosova and Hydra Bob like this.
  11. Spike83420
    Spike83420 , Jan 18, 2018 :
    My volume randomly decreases for no apparent reason just the last four updates.. this isn't the only one plus that has this problem either even the newer phones have the same problem so I would say that is a priority.
  12. F_Jorden_Grewal_QmtA
    never have I ever installed coustom ROM I don't even know why you brought that up
    volume was perfact and loud few months ago but after one OTA update it's been low. oneplus lowered the volume cause apparently it had some noise issues
    but in areas where there is lot of noise of cars and other stuff we can't even hear a ringtone. it's impossible to hear it when you are driving.
    it wouldn't have been a problem if they reduced a little but the difference is huge. @OnePlus
    Lirbra likes this.
  13. tpati
    In previous devices and lastest OSS when cache is clear allways goes to zero. I'm talking in the moment when is cleared because if you open any app off course this number will grow up, this is why is name is cache.
    Now when this is cleared allways stay on 4.30MB (1,2,3 times never goes to zero), I'm asking to know if is only me or not
  14. Deactivated User
    Jan 18, 2018
    Hydra Bob likes this.
  15. tpati
    I known it's not a big deal, next OTA update I will do a factory reset. Didn't do anyone after buyet Oneplus 3T.
  16. Bobbie63
    Bobbie63 , Jan 18, 2018 :
    Read this:
    http://mobileinternist.com/clear-cache-android-oreo
  17. tpati
  18. Bobbie63
    Then don't read it.
  19. joker_chile
    Eclair Jan 18, 2018
    joker_chile , Jan 18, 2018 :
    Hi Vaibhav....the issue remained same on the safe mode as well. I guess I'll give up,tired of factory reset and clean install again and again. Can you place tell me if I can rollback to 4.5.1 using the guide that you posted,since it seems to be for people on beta while mine was a stable update. And yeah, screenshot attached for the safe mode.
  20. Hydra Bob
    It will work the same regardless of whether you're on stable or beta
