451
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. G_Irek_Kayastha_eLVR
    Donut Jan 18, 2018
    G_Irek_Kayastha_eLVR , Jan 18, 2018 :
    Software bug in oneplus 3: Earpiece volume low during call..how to fix it??? and using earphones while making and receiving calls.
    Spike83420 likes this.
  2. dreamkiller1295
    Cupcake Jan 18, 2018
    dreamkiller1295 , Jan 18, 2018 :
    I have some questions about the 5.0 and 5.0.1 updates,
    As 5.0 updates the phone to Android 8.0, I didn't update it as some of the apps I frequently use may have problems with the new Android,
    as far as I know, 5.0 was later pulled down for many issues, then, comes 5.0.1,
    This update automatically got downloaded and it stays notifying me to reboot to install the update, here are the questions:
    1. Does 5.0.1 update your phone to Android 8.0 (Oreo)?
    2. Is there a way to reboot without installing the update, that is if the update installs Android 8.0 to the phone? As my phone starts to slowdown a bit for more than a week without switching off, I really wanna reboot it, but I still do not want to update to Oreo yet...
    Many thanks!
  3. ghostofcain
    Marshmallow Jan 18, 2018
    ghostofcain , Jan 18, 2018 :
    But isn't that the idea, this is a beta build, more bugs equals more bug reports which in turn leads to a better stable release.
    Hydra Bob likes this.
  4. Hydra Bob
    Hydra Bob , Jan 18, 2018 :
    Yes 5.0.1 is Oreo too. And I don't know for sure as I've never tried it but deleting the .Ota folder should stop it from updating if I understand correctly. You'll have to redownload it if you do decide to upgrade though.
  5. mefxes
    Eclair Jan 18, 2018
  6. kowshikpsg
    Froyo Jan 19, 2018
    kowshikpsg , Jan 19, 2018 :
    temporarily no voice service available at your location ( notification came often after the update any solutions)
  7. rahulchaks
    Honeycomb Jan 19, 2018
    rahulchaks , Jan 19, 2018 :
    everything works fine except there are frequent app crashes..... they open on second attempt but the crashes are annoying too
  8. Shashank H
    Gingerbread Jan 19, 2018
  9. ferry hidayat
    Eclair Jan 19, 2018
    ferry hidayat , Jan 19, 2018 :
    The funny thing is, This IS NOT a beta build. User are not QA tester. I don't understand why product manufaturer think end user as QA tester nowadays.
    I find the OOS v5 is by far the worst Oxygen OS. I downgraded to Nougat after sacrificing my time and mobile data.
    I will never upgrade to OOS v5 ever again.
  10. ghostofcain
    Marshmallow Jan 19, 2018
    ghostofcain , Jan 19, 2018 :
    Yes.
    Yes deleted the .OTA file from your device and the update won't be able to proceed.
    Oops thousand apologies I appear to have cross posted,. You're right although your experience does appear to be contrary to many on here,
  11. Spike83420
    Spike83420 , Jan 19, 2018 :
    My experience has been good except for my volume randomly decreasing while watching media or on speakerphone. Has been happening since the last 4 updates with no resolution...
  12. Rahul Dayal
    Rahul Dayal , Jan 19, 2018 :
    ghostofcain
    But isn't that the idea, this is a beta build, more bugs equals more bug reports which in turn leads to a better stable release.​
    bro I'm talking about OTA update
    I've got OTA UPDATE OF 5.0.1 oxygen os
    which are having lots of bugs
    it's lagging
    and battery drains like hell
    I have to charge at least twice a day , before the update everything was good
    average memory usage increased after the update
    why would that happen if my usage is still the same as before the update ?
    I don't even play heavy games like asphalt and all
    Lirbra and Abhi Dahiya like this.
  13. sergiostylo
    Cupcake Jan 19, 2018
    sergiostylo , Jan 19, 2018 :
    When you are in an app during an ongoing call. It would be nice to see the wifi signal. And to be able to activate the loudspeaker and deactivate the microphone only by displaying the notification bar (now you can only hang up the call but no more options. There is enough space for these functions)
    Lirbra likes this.
  14. kunal.h222
    KitKat Jan 19, 2018
    kunal.h222 , Jan 19, 2018 :
    if u switch data to another sim then jio won't work as jio is only 4g network.
    if you are aware of this then use Jio sim in 2nd sim slot.wipe cache in recovery mode.reset sim APN to defualt
    Sun90 and Ibrahim Attar like this.
  15. kalander Shihab
    Ice Cream Sandwich Jan 19, 2018
    kalander Shihab , Jan 19, 2018 :
    I've submitted logs to OnePlus devs regarding the memory management.
    Should be fixed in the next update.
    sergiostylo and Rahul Dayal like this.
  16. Ibrahim Attar
    Ibrahim Attar , Jan 19, 2018 :
    Thanks for your suggestions i will try it [e]1f44d[/e]
    kunal.h222 likes this.
  17. Spike83420
    Am I able to downgrade from Oreo to nougat without a computer I've read that I can sideload it but I'm not sure on how to go about doing that
  18. Sun90
    Starting Point Expert Jan 19, 2018
    Sun90 , Jan 19, 2018 :
    Read the pinned guide for the same.
    Bobbie63 and kunal.h222 like this.
  19. Spike83420
    Does it matter if I use the mirror link or the regular one?
  20. samirhasan01
    samirhasan01 , Jan 19, 2018 :
    It is horrible, my battery is terrible now
