450
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. joker_chile
    Eclair Jan 27, 2018
  2. DLYADAV
    Gingerbread Jan 28, 2018
  3. Saikumar7
    Ice Cream Sandwich Jan 28, 2018
    joker_chile likes this.
  4. fdroko
    Jelly Bean Jan 28, 2018
    fdroko , Jan 28, 2018 :
    this is stock o_O
  5. H1517115484394
    Cupcake Jan 28, 2018
  6. Mrsaffy128
  7. fdroko
    If you want a hasty update, get to work on the development and you have it o_Oo_O
    factory reset o_O
  8. ssintu19
  9. K1517178207402
    Donut Jan 28, 2018
  10. roadrrunner
  11. flemish_elite
    Donut Jan 28, 2018
    flemish_elite , Jan 28, 2018 :
    Accu - > optimalisation
  12. roadrrunner
    roadrrunner , Jan 28, 2018 :
    if you meant "apps" I tried that already, it didn't work
  13. Prahallad
    Froyo Jan 29, 2018
    Prahallad , Jan 29, 2018 :
    Please update the SMS blocker so it can block all TYPE of sms ie AO678990, AIABGHH,DTHGHHJ, VD356546
  14. Sun90
    Starting Point Expert Community Expert Jan 29, 2018
    Sun90 , Jan 29, 2018 :
    Why don't send a DND request to your service provider instead.
    idkwhoiam322 and VaibhavBhargava like this.
  15. VaibhavBhargava
    Lollipop Jan 29, 2018
    VaibhavBhargava , Jan 29, 2018 :
    Are you running some custom ROM ? If that is the case, I hope these will be of some help
    https://forums.oneplus.net/threads/...s-3-3t-and-go-back-completely-to-stock.456232
    and https://forums.oneplus.net/threads/guide-oneplus-3-3t-unbrick.531047/
    If you are on beta then you should read the beta thread as it is described by Adam what exactly should be done
    You will have to get that camera module changed, just mention it to the service centre guys that a software update caused this and they should do it for free.
    Deactivated User and Sun90 like this.
  16. Paschfire
    KitKat Jan 29, 2018
    Paschfire , Jan 29, 2018 :
    No. you are eagerly waiting for an OTA, I'm just fine thank you.
  17. prashanth.jagannath
    Eclair Jan 29, 2018
    prashanth.jagannath , Jan 29, 2018 :
    This goes for everyone who had updated via the OTA and are having issues. I had done the same and was facing issues with the Cellphone network, WiFi and a result of these was the battery drain. The WiFi speeds were very low though on my 4 year old Oneplus One, they were really good. The Cellphone signals were also choppy as I could see from the "Cellular network signal" section of the battery details.
    I was so tired of Oreo, I rolled back to Nougat. But, then wanted to see how a fresh install would look like and downloaded the Oreo OTA and applied it and reset the phone. Its just fine from then onwards and most importantly, I am not seeing the overnight battery drain due to WiFi and Cellphone Signal issues.
    Hope this helps
    lkosova likes this.
  18. joker_chile
    Eclair Jan 29, 2018
    joker_chile , Jan 29, 2018 :
    Thanks... Did that a while ago. Will wait for few full charge cycle to see if the performance gets better.
  19. Saikumar7
    Ice Cream Sandwich Jan 29, 2018
    Saikumar7 , Jan 29, 2018 :
    ok as ur wish
  20. Saikumar7
    btw wat sot ur getting in oreo??
