452
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. Strik3one
    Cupcake Feb 3, 2018
    Strik3one , Feb 3, 2018 :
    I need help here. after. formating/factory reset i. now facing heating issues even. simple watching movie in YouTube unusual heating please fix.
  2. smitmakani
    Froyo Feb 4, 2018
    smitmakani , Feb 4, 2018 :
    Can we expect New Stable release Today ?
    i am on beta and want to go for stable.
    thanks devs for your all supports.
  3. N1516510407263
    Cupcake Feb 4, 2018
  4. Radhwan
    Cupcake Feb 4, 2018
    Radhwan , Feb 4, 2018 :
    Voicemail notification is not working after the update.
    I don't get voicemail notifications. I have to reboot the phone to get the notification. and then I won't get any subsequent notifications until I reboot again.
    Omar.Meer likes this.
  5. Nikhil_Kolte
    Cupcake Feb 4, 2018
    Nikhil_Kolte , Feb 4, 2018 :
    bro i did thereset worked for about a month and not working again now
  6. Ibrahim Attar
    Honeycomb Feb 4, 2018
    Ibrahim Attar , Feb 4, 2018 :
    It's normal dark theme of OnePlus, no custom rom.
  7. Omar.Meer
    Cupcake Feb 4, 2018
    Omar.Meer , Feb 4, 2018 :
    I am having the same issue with voicemail and text messages also. Sometimes other notifications, but primarily voicemail and text.
    This was never an issue in the past.
    Radhwan likes this.
  8. Sockerle
    Eclair Feb 4, 2018
  9. G_Sergiu_Iacob_SPrU
    Gingerbread Feb 4, 2018
    G_Sergiu_Iacob_SPrU , Feb 4, 2018 :
    wtf is that supposed to mean, they stopped rolling out anything official for the OP3? ARE YOU BLIND? A new beta (31) has just been released. they continously release updates for these device. get outta here and stop complaining about something that's not true, you're pathetic.
  10. Sockerle
    Eclair Feb 4, 2018
  11. zad3
    Eclair Feb 4, 2018
    zad3 , Feb 4, 2018 :
    good thing is i am not facing any of the above mentioned problems, is it more likely cuz i did not break my os n installed beta? well all good though.
  12. FPisto
    Cupcake Feb 4, 2018
    FPisto , Feb 4, 2018 :
    I don't know if it's a setting, or from the beta, but when i open the application menu, i'm on the bottom of it
  13. The_Voice_70
    Eclair Feb 4, 2018
  14. Sun90
    Starting Point Expert Feb 4, 2018
    Sun90 , Feb 4, 2018 :
    It's a bug fix update and apart from,it's not made official ,hence there's no full zip file to download for now from oneplus site.
  15. Swaroopadiraj
    Cupcake Feb 5, 2018
    Swaroopadiraj , Feb 5, 2018 :
    i have open beta 15 can i download this straight away and install ?
    or there is a special build to do so? pls reply
  16. Sun90
    Starting Point Expert Feb 5, 2018
    Sun90 , Feb 5, 2018 :
    You can.
    No need for a spl build.
    Bobbie63 likes this.
  17. Swaroopadiraj
    Cupcake Feb 5, 2018
    will it revert back to stable version?
  18. Sun90
    Yes.
    But a factory reset would be needed ,if you face any issue after flashing this stable build.
    Bobbie63 and Swaroopadiraj like this.
  19. Yannis Neris
    Ice Cream Sandwich Feb 5, 2018
  20. sharkyslo
    Gingerbread Feb 5, 2018
    sharkyslo , Feb 5, 2018 :
    After 5.0.1 update, my OP3 is lagging constantly. I think, the reason is OnePlus Launcher, which is closing itself sometimes... Even after OnePlus Launcher update, the situation is the same...
