452
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. Felix_Rhau
    Eclair Feb 13, 2018
    Felix_Rhau , Feb 13, 2018 :
    I'm encountering some serious bugs in this build... For example is the SMS Text Messages App crashing and not even able to receive SMS Text messages from for example the phone provider (Tested). Also are Third Party Apps crashing after some time... o_O
    ArunMalik1Plus likes this.
  2. ruhela786
    Ice Cream Sandwich Feb 14, 2018
  3. VaibhavBhargava
    Lollipop Feb 14, 2018
    Shashank H and Sun90 like this.
  4. G_Sandy_Killington_Rsyj
    Froyo Feb 14, 2018
  5. maortrol
    Honeycomb Feb 14, 2018
    maortrol , Feb 14, 2018 :
    Nobody knows.
    Sun90 likes this.
  6. G_Sandy_Killington_Rsyj
    Froyo Feb 14, 2018
    G_Sandy_Killington_Rsyj , Feb 14, 2018 :
    oneplus are so lazy they are not pushing update for 3/3t because they are older phone rhey are only pushing updates for oneplus 5 and 5t because they are new devices[e]1f621[/e][e]1f621[/e][e]1f621[/e][e]1f620[/e][e]1f620[/e][e]1f620[/e][e]1f620[/e]
  7. G_Sandy_Killington_Rsyj
    Froyo Feb 14, 2018
  8. multy
    Eclair Feb 14, 2018
  9. N1518612207622
    Cupcake Feb 14, 2018
    N1518612207622 , Feb 14, 2018 :
    My phone is ringtone volume automatically small and no vibration so more time I'm not proper receiving important calls an this problem start before 2/3 days.
  10. Pradeep@1+
    Pradeep@1+ , Feb 14, 2018 :
    Don't expect any updates this week, not even beta, as it was Holidays there in China for Chinese New Year and all OP staffs might be having fun :D:D:p:p
    N1518612207622 likes this.
  11. K_Praneeth_Reddy
    Froyo Feb 14, 2018
    K_Praneeth_Reddy , Feb 14, 2018 :
    when i flash twrp and reboot the phone it goes back to stock recovery. I don't know what's wrong it used to work well in previous versions of Oos
    Does anyone know how to fix this issue?
  12. Sun90
    Starting Point Expert Feb 14, 2018
    Sun90 , Feb 14, 2018 :
    After flashing twrp you should reboot phone to twrp recovery first and then from there you reboot phone to system.
  13. K_Praneeth_Reddy
    Froyo Feb 14, 2018
    i tried this way also but it didn't work
  14. kalander Shihab
  15. Yannis Neris
    Yannis Neris , Feb 14, 2018 :
    Flash root ( supersu or magisk) before you boot to system... otherwise after you boot, twrp becomes replaced from stock recovery...
  16. K_Praneeth_Reddy
    Froyo Feb 14, 2018
    twrp shows that not able to stop stop stock recovery from replacing twrp so some activities like rooting is will not work.
    As mentioned by the twrp it didn't work
  17. Yannis Neris
    What are you talking about...??
    If you want to make twrp stick ....
    Flash supersu or magisk zip and then reboot to system....
  18. fdroko
    Jelly Bean Feb 14, 2018
    fdroko , Feb 14, 2018 :
    2020
  19. piyushshekhar2008
  20. RASTAVIPER
    RASTAVIPER , Feb 14, 2018 :
    Hundreds of people have done it and you just came here to write that it doesn't work.
    Next time try to read better the rooting instructions instead of making fool of yourself.
    Boot in TWRP and flash magisk or a custom kernel before rebooting.
    Sun90 likes this.
