452
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. OPO OOS lover Jelly Bean Feb 17, 2018
    OPO OOS lover, Feb 17, 2018 :
    Ok thanks for the information
    Deactivated User likes this.
  2. Pepsican Froyo Feb 17, 2018
    Pepsican, Feb 17, 2018 :
    With regards to battery drainage, check the various threads on the forum to fix it.
    Release 5.0 was only temporarily halted. If continued eventually.
    Yes, you should update. If only for the security fixes.
  3. N1516510407263 Cupcake Feb 18, 2018
    N1516510407263, Feb 18, 2018 :
    no I am talking about battery displayer, how he had done it?
  4. Ibrahim Attar Honeycomb Feb 18, 2018
    Ibrahim Attar, Feb 18, 2018 :
    Go to settings>status bar>battery style, select battery circle.
    Sun90 likes this.
  5. N1516510407263 Cupcake Feb 18, 2018
    Ibrahim Attar likes this.
  6. 6738 Cupcake Feb 20, 2018
    6738, Feb 20, 2018 :
    Hi, I'm using one plus 3T, after OS 5.0.1 OTA my fingerprint not working. could you help me about this issue please??
  7. RASTAVIPER Jelly Bean Feb 20, 2018
    RASTAVIPER, Feb 20, 2018 :
    Did you perform a factory reset after upgrading to 5.0.1 ?
    kunal.h222 likes this.
  8. 6738 Cupcake Feb 20, 2018
    No, don't know how to do that... could you let me know the options please?
  9. Deactivated User Feb 20, 2018
  10. Luxemberg Nixon X Honeycomb Feb 20, 2018
    kpoyser likes this.
  11. anz563 Ice Cream Sandwich Feb 20, 2018
  12. ruhela786 Ice Cream Sandwich Feb 20, 2018
    Sun90 likes this.
  13. Deactivated User Feb 20, 2018
  14. 6738 Cupcake Feb 20, 2018
    when we perform factory reset, do we lose the entire phone data please???
  15. Anonymous_unknown Froyo Feb 20, 2018
    Anonymous_unknown, Feb 20, 2018 :
    Yes, all data will be lost.
    Create a backup and store it externally on pc or hd
  16. kpoyser Gingerbread Feb 20, 2018
    kpoyser, Feb 20, 2018 :
    not necessarily. They're 2 options that you receive when doing a factory update from within the operating system. 1 option is to wipe the entire phone including user data and on other option which keeps user data in tact and erases all applications.
    if the reset is done from the recovery partition then you may not be given an option to retain user data
  17. ruhela786 Ice Cream Sandwich Feb 21, 2018
    ruhela786, Feb 21, 2018 :
    I'm no expert but i think OnePlus has made some changes in the kernal with 5.0.2 so the battery life is not great as it use to be on 5.0.1
  18. gaurav.malhotra Honeycomb Feb 21, 2018
    gaurav.malhotra, Feb 21, 2018 :
    there are 2 options in recovery as well.
    kpoyser and Sun90 like this.
  19. elkhan Gingerbread Feb 21, 2018
    elkhan, Feb 21, 2018 :
    There are more serious issues in this update than even battery, like I cannot hear anything during calls. This makes the phone totally useless without earphones.
    OP when fixes something, destroys something else more important.
  20. VaibhavBhargava Lollipop Feb 21, 2018
    VaibhavBhargava, Feb 21, 2018 :
    That's what stable users get for telling the devs to focus more on quantity (features) over quality (polished builds)
    Sun90, elkhan and jasprjay like this.
