450
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. Deactivated User
    Apr 24, 2018
  2. Bogeyd
    Gingerbread Apr 24, 2018
    Bogeyd , Apr 24, 2018 :
    You have enabled syncing within the account? I had also some freezes in Chrome before I clear up browsing data.
    It was not enough to do in mobile, but also in laptop. After that no lag any more when browsing. Maybe it tries to sync the open tabs and hangs. Also maybe try to reduce amount of bookmarks if it is in thousands.
    Clear the browsing data on all devices you use to sync with the same account (laptop, mobiles, tablets etc). Here how to do in Android.
    Click three dots -> settings -> privacy -> clear browsing data -> advanced
    Set time range all and check all then click clear data.
    PTuT likes this.
  3. F1522321999072
    Cupcake Apr 24, 2018
    anz563 likes this.
  4. Anzik
    Ice Cream Sandwich Apr 24, 2018
    Anzik , Apr 24, 2018 :
    never
  5. elkhan
    elkhan , Apr 24, 2018 :
    Did anyone face this issue - I started getting "Low storage space" warnings from the system, after I started using the 2nd SIM slot. It is very strange and I think this is a bug because, I had 55% full storage before, now it is 99% without any addings to the storage. However, I removed about 7 GB of data, and storage is still 99% full.
  6. DLYADAV
  7. Bobbie63
    Marshmallow Apr 24, 2018
    Bobbie63 , Apr 24, 2018 :
    And if you reboot?
    Sun90 and ghostofcain like this.
  8. VaibhavBhargava
    Lollipop Apr 25, 2018
    VaibhavBhargava , Apr 25, 2018 :
    What happens if you remove all the fingerprints followed by clearing the system cache from the recovery menu ?
    They said we could start expecting 8.1 around mid 2018, not sure whether the stable or beta version.
    Sun90 likes this.
  9. elkhan
    Gingerbread Apr 25, 2018
    elkhan , Apr 25, 2018 :
    I rebooted, did cache wipe. Even reset to system default. The problem persists, when 2 SIM slots are used.
  10. Bobbie63
    Marshmallow Apr 25, 2018
    Bobbie63 , Apr 25, 2018 :
    Have you checked in the file manager if there are oem_logs?
    Sun90 likes this.
  11. Andrei R.
    Ice Cream Sandwich Apr 25, 2018
    Andrei R. , Apr 25, 2018 :
    It is probably beta since ~1-2 months until mid 2018. I don't believe they will release in 1-2 months the beta version and then the stable one.
  12. VaibhavBhargava
    Either ways a good news
    Sun90 likes this.
  13. Andrei R.
  14. F1522321999072
    Cupcake Apr 25, 2018
    F1522321999072 , Apr 25, 2018 :
    I don't understand. then what's the point of releasing the beta versions of is if they aren't planning to launch the stable one. any ideas??
  15. G_James_Taaffe_MYxD
    Ice Cream Sandwich Apr 26, 2018
    G_James_Taaffe_MYxD , Apr 26, 2018 :
    this is the best battery I have had in a long while. after open beta 24 onwards my battery life deceased significantly. I have literally done wipes and custom ROMs and Greenify and nothing prevailed. until.... I flashed back to nougat using the special build, from there I flashed 5.0.1 and factory reset. I'm not saying this is a cure but I hope maybe this might work for someome else
  16. rl6766
    Cupcake Apr 26, 2018
    rl6766 , Apr 26, 2018 :
    the notification bar becomes dark after update , where can i setting it?
  17. rdx22
    Eclair Apr 26, 2018
    rdx22 , Apr 26, 2018 :
    how mush battery backup are you getting from a single full charge ?
    can you guys share some screenshots ?
  18. elkhan
    Gingerbread Apr 26, 2018
    elkhan , Apr 26, 2018 :
    Yes, there are some. Can I delete them?
  19. Sun90
    Starting Point Expert Community Expert Apr 26, 2018
    Sun90 , Apr 26, 2018 :
    Yes, you can delete them.
    Bobbie63 and elkhan like this.
  20. DrVikTroll
