450
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. Winay00
    Gingerbread May 12, 2018
    Winay00 , May 12, 2018 :
    I had done a reset 3months back bcoz of sum buggy app which was leading to ads on my fone..
    After reset everything was solved ....
    I have been looking for solution in the posts...Sum ppl saying to root the fone.
    Sum ppl saying flash it with new software etc.
    I am looking for original nougat os with oxygen 4.5.5....
    I just want a simple solution.
    Rooting my fone with new software etc might ruin my fone if i do it wrong.
  2. noisy.lightning
    Eclair May 12, 2018
    noisy.lightning , May 12, 2018 :
    In which case have a look on the one plus website download section. They should have a list of install files for you to manually install. If not the XDA forum has a post with all the old versions.
    https://r.tapatalk.com/shareLink?ur...share_tid=3468628&share_fid=3793&share_type=t
  3. Bobbie63
    Marshmallow May 13, 2018
    Bobbie63 , May 13, 2018 :
    Just do a clean install, wipe everything an install 5.0.1 again, don't restore the apps from Google play, add the apps manually.
    Should that work, you always can go back to Nougat using this:
    https://forums.oneplus.com/threads/guide-how-to-go-from-oreo-to-stock-nougat.661713/
    VaibhavBhargava likes this.
  4. Winay00
    Gingerbread May 13, 2018
    Winay00 , May 13, 2018 :
    I have tried reset..but no use...
    i will try to use the link to go back to nougat..
    Actually i dont know manual upgrading stuff...
    Then too i will try...if i have no other option...
    like service centre etc..
    Bobbie63 likes this.
  5. Bobbie63
    If you follow the steps, as given in the link I gave you, you'll be fine. All necessary links are given also in that thread.
    lkosova likes this.
  6. RASTAVIPER
    Jelly Bean May 13, 2018
    RASTAVIPER , May 13, 2018 :
    Let me get this straight.
    Have u done a factory reset and then what was the problem?
  7. G_Sandor_N._Tavares_KiKD
    Eclair May 13, 2018
  8. Nilesh.Prajapati
    Froyo May 14, 2018
  9. Riddhesh Khatu
    Gingerbread May 14, 2018
    Riddhesh Khatu , May 14, 2018 :
    yes even i am facing the issue even though the storage permission is enabled for the app
  10. moldayajib
  11. mikica023
    Honeycomb May 14, 2018
  12. moldayajib
    moldayajib , May 14, 2018 :
    ooh i see, thank you
  13. wospino
    Ice Cream Sandwich May 14, 2018
    wospino , May 14, 2018 :
    3 years old and it's rocking better than the first day, sometimes the problem is who looking the phone, and not the phone, sad but true.
  14. Winay00
    Winay00 , May 14, 2018 :
    This is the issue after updating...Getting black dot below screen every 3 to 4mins...
  15. dermot33
    dermot33 , May 14, 2018 :
    Just hard reset my OnePlus 3 because I'm selling it,having been on beta for very long time I'm disappointed to see that The stable hasn't been updated in 6 months,very poor from OnePlus. Feeling a bit better about my decision to buy Nokia 7 plus
  16. iamspini
    Froyo May 14, 2018
    G_James_Taaffe_MYxD likes this.
  17. G_James_Taaffe_MYxD
  18. G_James_Taaffe_MYxD
  19. G_James_Taaffe_MYxD
  20. Winay00
    But howcome this dot started only after updating to oreo ...Before there was no such issue.
