450
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. elkhan
    Gingerbread May 22, 2018
    elkhan , May 22, 2018 :
    Hello. We are talking about security updates, which are already half a year old. Not about new features. I don't care about OP's new features, they are useless anyway,
    f00tbaLL, marco_sporte and nabsrai like this.
  2. bulletant
    Froyo May 22, 2018
    bulletant , May 22, 2018 :
    Agree. I just want my phone to be stable and has a good battery performance.
    marco_sporte and jasprjay like this.
  3. Bobbie63
    Marshmallow May 22, 2018
    Bobbie63 , May 22, 2018 :
    What do you think, Nougat and Marshmallow are safe, where most phones still are on??
    As if they get regular updates. Dream on.
    Sun90 likes this.
  4. RASTAVIPER
    Jelly Bean May 22, 2018
    RASTAVIPER , May 22, 2018 :
    Lol.
    so you believe that a security update is offering stability and battery performance?
    Then you have no idea of what a security update stands for.
    f00tbaLL and jnsson like this.
  5. bulletant
    Froyo May 22, 2018
    I'm talking about the new features thing. I don't really need them and I think security update is more important as well.
    jasprjay likes this.
  6. F_Henrik_Madsen_wfQs
    Honeycomb May 22, 2018
    F_Henrik_Madsen_wfQs , May 22, 2018 :
    Lamest argument ever.
    Normally i dont complain, and i understand that the manufacturer will not supply updates forever.
    But there are 2 different things here.
    1. New versions of android and feature updates.
    2. Security updates
    If you compare to microsoft windows, you also need to buy a new version once in a while and as soon as microsoft releases a new version, the old one will not get any feature updates.
    But security updates on the other hand, microsoft supplies these for years for older versions.
    I dont care about feature updates and i understand that my OP3 will never officially get android 9.
    But security updates on the other hand, i would expect longer.
    Please remember that the 3T was released on november 20 2016.
    This means that until now, the Oneplus 3 has only received updates for 1 year and 1 month after it was superceeded, and many OP3's have been sold as new after that date.
    So basically OP has decided that security updates should only be available for less than a year from the last unit was sold from new.
    In my opinion anything less than 2-3 years of regular security updates is not good.
    Sends a signal to the buyer that OP only expect the phone to last for 1 year.
    If it still works after that, it will atleast be dangerous to use due to bugs not being fixed.
    Also the 3T is almost identical so updates for both are made at the same time.
    scorpyix likes this.
  7. Bobbie63
    Where did they state they're not giving security updates??
    The beta versions are on May security patch. If you're so concerned about security, use beta.
    What's so important about the latest patches, what happened in Android land you all of a sudden need the latest security patch?
    I don't say we don't need them, but I found the majority of people asking for updates are not talking about security updates. If updates take too long, they throw in the security "card" just to put more weight in the scale.
  8. jnsson
    jnsson , May 22, 2018 :
    I fully agree. I can't care too much about security update, but IF a new update release if should have the latest security update as well. I haven't upgraded to Android Oreo yet, and therefore I'm still om september 2017 security patch level
    Bobbie63 likes this.
  9. H1526999433905
    Cupcake May 22, 2018
  10. Bobbie63
    Of course it should have the latest patch, I fully agree with that. The thing is all of a sudden, security patches became "so important". We should keep receiving security patches and I hope we will receive them for a certain amount of time.
    But at this moment, people just want "security patches" to put more force on OnePlus for getting updates in general than the fact they're worried about their so-called safety.(as if that would work). :)
    Sun90 likes this.
  11. dcop7
    dcop7 , May 22, 2018 :
    First, that is an improper language. Second, it is possible that your speaker problem is not oneplus fault. Could be that it got water, it dropped, etc... To check, try a factory reset.
    And I say again, that is an improper language. If you use that language, just doesn't use it here.
  12. H1526999433905
    H1526999433905 , May 22, 2018 :
    I'm sorry about my language
    nothing happened to the speaker it's a software problem not a hardware problem
  13. H1526999433905
  14. dcop7
    How
    How do you know? Probably a reset will fix it. But if you don't want to do that...
    jnsson and f00tbaLL like this.
  15. pxrave
  16. G_Alex_Magistro_koiC
    Donut May 22, 2018
    f00tbaLL likes this.
  17. iamspini
    Froyo May 22, 2018
    iamspini , May 22, 2018 :
    They didn't. Things are slowing down but they didn't stop
  18. G_Alex_Magistro_koiC
    Donut May 22, 2018
  19. iamspini
    Froyo May 22, 2018
    you're welcome
  20. PTuT
    Jelly Bean May 23, 2018
    PTuT , May 23, 2018 :
    I fully understand you. Phone on the stable OOS release should not need to go through phone reset to fix software problem. I can see it as a solution for the beta releases. Maximum to clear the cache.
    rajeev5252 likes this.
