451
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. Sheik_Yerbouti
    Honeycomb Dec 30, 2017
    Sheik_Yerbouti , Dec 30, 2017 :
    +1. I had to do this after the update as well.
  2. ruhela786
    Ice Cream Sandwich Dec 30, 2017
    ruhela786 , Dec 30, 2017 :
    How many charge cycles?
  3. Sheik_Yerbouti
    Punk_69 and ruhela786 like this.
  4. isht_kundu
    Donut Dec 30, 2017
    isht_kundu , Dec 30, 2017 :
    The update looks good just give is the option to select the no. of tiles in a row in the quick settings and make them exapandable again like in nougat
  5. G_MD_Fahad_RxaV
    Froyo Dec 30, 2017
  6. moonie.hermoso
    Froyo Dec 30, 2017
    moonie.hermoso , Dec 30, 2017 :
    Good to know.
  7. ruhela786
    And you should not be dumb, but here we are.
  8. Abhishek Bhati
    Donut Dec 30, 2017
  9. maheshzx
    Gingerbread Dec 30, 2017
    maheshzx , Dec 30, 2017 :
    • Adaptive mode is named as Soft in display calibration.
    • Quick tiles color pallette is re-designed ( like nougat )
    • Bluetooth codec is under advanced settings
    • Fingerprint vibration is removed, to turn on use vibrate on tap option.
    So far all apps are working good no lags or whatsoever.
  10. Spike83420
    Spike83420 , Dec 30, 2017 :
    Has the volume bug been fixed I've had it since the last 2 to nougat updates and this past Oreo
  11. Andrei R.
    Andrei R. , Dec 30, 2017 :
    Why don't you try it since we don't experience this bug you're calling?
    ghostofcain likes this.
  12. SahilQureshi
  13. PTuT
    Jelly Bean Dec 30, 2017
    PTuT , Dec 30, 2017 :
    Tried, no change. Cleared the cache too. Will try some other tricks. Thanks.
  14. Spike83420
    If I turn my speaker on the volume will be super loud and then slowly go quieter same thing with media will be very loud and then go extremely quiet I'm even missing alarms to wake up now it comes and goes whenever there's nothing I could do other than stick a headphone jack in and pull it out every so often and that seems to fix it ironically... Also if you search the volume bug I'm not the only one with this issue it's out there
  15. Andrei R.
    I don't have this so I can't relate. Sorry
  16. Bhavya Aggarwal
    Eclair Dec 30, 2017
    Bhavya Aggarwal , Dec 30, 2017 :
    it's nice that you qre giving update to OnePlus 3/3t even after android 8 update....and also plsss give us face unlock
    mariogold42 likes this.
  17. Spike83420
  18. Aditya_R_Rao
    Cupcake Dec 30, 2017
    Aditya_R_Rao , Dec 30, 2017 :
    I'm not able to add/move apps on the home screen.
    And, cannot access the UI settings (long press on the home screen)
    Apps from the 2nd home page have disappeared.
    please fix this ASAP
  19. stanis40
  20. mariogold42
