450
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. Ajitharun
    Donut Dec 31, 2017
  2. manimaarans
    Honeycomb Dec 31, 2017
    manimaarans , Dec 31, 2017 :
    yeah it worked after toggle it once . didn't know that it would be this simple.
  3. mevicks
    Ice Cream Sandwich Dec 31, 2017
    mevicks , Dec 31, 2017 :
    I'm on a clean install on v5.0.1 and this is applicable by default. No extra steps needed
  4. broeckelman
    Cupcake Dec 31, 2017
    broeckelman , Dec 31, 2017 :
    I´ve got an problem with this update. After downloading and installation of the update my phone wont start. Even if i try to start the recovery mode nothing happen. Can someone help me please?
    When i connect my phone to my computer, it detect the device as "QUSB_BULK" a moment later it is detected as "Qualcomm HS-USB QDLoader 9008 (COM3)" but i dont have access to ms device.
  5. utkarshns
    Froyo Dec 31, 2017
    utkarshns , Dec 31, 2017 :
    I don't think it if to do with SMS centre number. I can't even open the stock OnePlus Messaging app. The Google messages app opens but throws the error "Failed to create conversations..."
    I tried the usual wipe and clear data. But no gain. Will try deeper cleaner methods once I get back home.
  6. tejaslrajput
    Gingerbread Dec 31, 2017
  7. supermunny
    supermunny , Dec 31, 2017 :
    Happy with this update, fixed all the problems caused by the 5.0 update (Camera, YouTube & flashlight not working). Really glad I didn't have to do a hard reset on the phone.
  8. Bobbie63
    Marshmallow Dec 31, 2017
    Bobbie63 , Dec 31, 2017 :
    Keep us posted and good luck.
    Sun90 likes this.
  9. Zh_kilat
    Android Q Dec 31, 2017
    Zh_kilat , Dec 31, 2017 :
    Have you updated the Qualcomm driver?
    Sun90 likes this.
  10. broeckelman
    Thx for your response. Yes, the driver is updated
  11. Zh_kilat
    Sun90 likes this.
  12. Ehab_AbuAlSaoud
    Donut Dec 31, 2017
    Ehab_AbuAlSaoud , Dec 31, 2017 :
    Hello again
    I just wanted to say Thank You OnePlus Team for making the tiles in the Notification drawer white and removing fingerprint vibration! [e]1f601[/e]
  13. .Deleted_Member.
    Nougat Dec 31, 2017
  14. athaarv
    Jelly Bean Dec 31, 2017
  15. .Deleted_Member.
    Nougat Dec 31, 2017
    athaarv likes this.
  16. viSH69
    Donut Dec 31, 2017
    viSH69 , Dec 31, 2017 :
    I am facing same issue on this update.
    SMS don't work. As soon I try to open SMS app it closes in a flash.
    Tried downloading 3rd party message app but I am not able to receive any message although it shows message sent but other person not getting my messages.
    Tried reflashing, cache clearing etc but same issue.
  17. broeckelman
  18. G_Nikhil_sharma_WlyN
    Eclair Dec 31, 2017
  19. utkarshns
    Froyo Dec 31, 2017
    Have you dirty flashed?
    I have dirty flashed this 5.0.1 over OB19, which is the easy way for me. I really wanted this to work but will do a good old clean install in a while.
  20. Sun90
    Starting Point Expert Community Expert Dec 31, 2017
    Sun90 , Dec 31, 2017 :
    It's a Bluetooth audio codec to enhance the music quality.and thereby the listening experience.
    You have to use a compatible Bluetooth headset to experience it.
    For further info on it ,check / search on Google about aptx
