450
OxygenOS 5.0.1 OTA update for OnePlus 3 and 3T
  1. Aeron
    Gingerbread Jan 1, 2018
    Aeron , Jan 1, 2018 :
    Second post above yours :/
    Kushang Pandit likes this.
  2. Aeron
    Just came back from little ride. After 1.5 hours of Driving (GPS High ON, LTE network connected, Bluetooth Conected to car) I got from 60% to 40 % of battery. And that was with Spotify running (LTE streaming) and streaming to Car via Bluetooth on background while Waze was active. So very nice. Before it would take twice as much battery even on nougat.
    Slowly clapping to OnePlus.
    Kunlan and Sheik_Yerbouti like this.
  3. vijay8341
    Froyo Jan 1, 2018
    vijay8341 , Jan 1, 2018 :
    OnePlus has rollback the update, since the update has few bugs... so that's why we can't able to see the update even after connecting to different VPN's.. My advise is, wait until new update arrives..
  4. Yogesh Datar
    Honeycomb Jan 1, 2018
    Yogesh Datar , Jan 1, 2018 :
    new update now available, try any VPN app like turbo or opera VPN from Google app store.
    connect to either Canada or Germany through that app.
    go to system update and check for update.
  5. pojr
    Jelly Bean Jan 1, 2018
    pojr , Jan 1, 2018 :
    relax for one
    Bobbie63 likes this.
  6. maxium
    Eclair Jan 1, 2018
    maxium , Jan 1, 2018 :
    Updated the phine two days ago. Basically all works well, but have some minor bugs:
    1. One app (Privat24 - Ukranian bank client) crashes on start.
    2. Led indicator doesn't work on Gmail.
  7. Bobbie63
    Marshmallow Jan 1, 2018
    Bobbie63 , Jan 1, 2018 :
    Somehow I got a déjà vu. :confused:
    Sun90, lkosova and Kunlan like this.
  8. ruhela786
    Ice Cream Sandwich Jan 1, 2018
    ruhela786 , Jan 1, 2018 :
    Here are some ss of my battery usage stats, it's good cause i used mobile data for quite some time and i did used WiFi too. I hope it helps people to get some idea about the battery life of this update, but i know in the end it all depends on the usage of the users. I am a OP3 user btw.
    wutthiroj likes this.
  9. F_Piotr_Narewski_QroO
    Cupcake Jan 1, 2018
    F_Piotr_Narewski_QroO , Jan 1, 2018 :
    After I installed it, suddenly my 4G on Telcel/ México started working.
    Before I couldn't make it working no matter what.
    What has changed?
    Also, despite of having 4G working, it auto switches to H+ after awhile. I have to go to the settings and manually force it to use 4G.
    I never had problems with 4G in Europe, on the same phone. But it never worked in America, except Brazil one year ago.
    There is something really dodgy about OP3's 4G
  10. Anuj_Tambe
    Froyo Jan 1, 2018
    Anuj_Tambe , Jan 1, 2018 :
    As someone already pointed out, update has disabled vibration while unlocking using fingerprints. Unlocking via this option has also slowed down.
    Indian users : This update has enabled voLTE option on airtel. However, I am not able to latch to voLTE and network still falls to H+ while making calls.
  11. Deactivated User
    Jan 1, 2018
  12. gebla
    Eclair Jan 1, 2018
    gebla , Jan 1, 2018 :
    This is a really basic misstake. Even with the same software GOS performance is differenet per phone. For me GPS issues started after an update in August. Before that it worked fine. I now read that Oneplus 5 has GPS issues as well and a friend of mine had issue with GPS on Oneplus 2.Its just very annoying that we get no resposne at all from Oneplus or any fixes. But hey if you buy a cheap phone you can expect cheap support.
    Tommy11 likes this.
  13. Deactivated User
    Jan 1, 2018
  14. 1aroslav
    Eclair Jan 1, 2018
  15. fdroko
    fdroko , Jan 1, 2018 :
    the battery has good performance, however it can continue to improve o_O
  16. Sef10
    Froyo Jan 1, 2018
    Sef10 , Jan 1, 2018 :
    Do I need to have 5.0 before installing this 5.0.1 update?
  17. fdroko
    yes
  18. Bobbie63
    Unfortunately, the sad thing is, they are going to shove it up our...... :confused:
    Deactivated User likes this.
  19. Sef10
    Froyo Jan 1, 2018
    No, it's OTA
  20. pualai
    Eclair Jan 1, 2018
    pualai , Jan 1, 2018 :
    Are you sure?
