428
OxygenOS 5.0.2 OTA for the OnePlus 5
  1. aavsb93
    Donut Feb 6, 2018
    aavsb93 , Feb 6, 2018 :
    my camera app closes automatically after the update. need assistance
  2. Mithun Kumar Gumgaonkar
    Gingerbread Feb 6, 2018
    crzfyr likes this.
  3. akanksha96
    Cupcake Feb 6, 2018
    akanksha96 , Feb 6, 2018 :
    I feel camera quality is being compromised. and screen flicks while exiting from camera
  4. Ragesh.kollara
    Cupcake Feb 6, 2018
  5. Sun90
    Starting Point Expert Community Expert Feb 6, 2018
    Sun90 , Feb 6, 2018 :
    Update the app if any new version is available.
    Wipe data and cache of it and see.
    If still issue then contact the app developer.
  6. I1517935307391
    Cupcake Feb 6, 2018
    I1517935307391 , Feb 6, 2018 :
    I got my new oxygen OS 5.0.2 UPADTE and when I downloaded it ......
    and for some reason I paused it for some time.....
    and then resumed my downloading.....
    so at first it got completed .....and then it started to show that downloading failed......
    and now it's not getting re installed and its not getting downloaded again .....
    what should I do now?????....
    please reply ....ASAP.....
  7. flyingdad
    Ice Cream Sandwich Feb 6, 2018
    flyingdad , Feb 6, 2018 :
    Investigate and find the reason why. The ROM has probably nothing to do with your problem. A quick look on the Internet makes me think it is due to the application itself? Or to some interferences with some themes? Well, look by yourself .... Google-ize your problem ...
  8. Christian Schaal
    Eclair Feb 6, 2018
    Christian Schaal , Feb 6, 2018 :
    Your Battery is fine... what do you want more?
  9. J1509547149880
    Froyo Feb 6, 2018
    J1509547149880 , Feb 6, 2018 :
    Don't think so. Earlier at this stage, it used to be 17-18 hours approx :)
  10. Jopa
    Jopa , Feb 6, 2018 :
    does anyone know how to costumize Google search bar? I still can't edit mine!!
  11. Christian Schaal
    Eclair Feb 6, 2018
    Maybe your approx calculation is deffrent... that could be (never checked that), but your getting more than one hour of SOT of 10% of your Battery... that is like really good... definetly no Battery Drain
  12. J1509547149880
    Froyo Feb 6, 2018
    Hope u r right :). One more thing, sometime I see lag in ui like while opening watsapp, facebook or menu. What could be the reason? any suggestions
  13. Coladre
    Froyo Feb 6, 2018
  14. dasza1965
    dasza1965 , Feb 6, 2018 :
    For me that's the 1st version of OS in which I have planty situations when apps hangs. I cleaned cache, made reboot. For nothing. 3-4 times a day apps hangs.
    I had OPO, OP3 now OP5.
  15. garaba
    Cupcake Feb 6, 2018
    garaba , Feb 6, 2018 :
    Thank you for the update and especially the facial recognition, for cons there is a bug in the color change of the led charging battery is still on the blue
  16. lucky_ameta
    Honeycomb Feb 6, 2018
    lucky_ameta , Feb 6, 2018 :
    Face unlock is cool... However it will be coolest if unlocking device will unlock apps too. At least selected apps. Or face unlock can unlock apps too.
    Camera is the feature oneplus needs too much work. Guys do something. Camera hardware is awesome... Please dont ruin it with worst software... Work on it guys.
    Google camera app take far more better pics then stock camera...fix this issue
    crzfyr likes this.
  17. G_prateek_vashishth_ICbk
    Froyo Feb 6, 2018
  18. kdmanojkumar
    Froyo Feb 6, 2018
    kdmanojkumar , Feb 6, 2018 :
    Guys,
    Anyone facing the volume issue. ... ?
    Volume goes to low automatically and can't be changed to Max level until I restart the phone.
    Any one facing the same issue. ?
    Let me know if u guys found any solution.
    Thanks.
  19. Josiah1231
    metaloid2k16 likes this.
  20. j0k3rip
