428
OxygenOS 5.0.2 OTA for the OnePlus 5
  1. koncek
    Donut Feb 7, 2018
    koncek , Feb 7, 2018 :
    I have the same issue. Usually around 3PM the device was around 70%, it's 1PM and it's 30%.
    Only solution is rollback?
    metaloid2k16 likes this.
  2. pawan jakhar
    Cupcake Feb 7, 2018
  3. Burgletrouser
    Eclair Feb 7, 2018
  4. Josiah1231
    Gingerbread Feb 7, 2018
    Josiah1231 , Feb 7, 2018 :
    in my experience, I did a hard wipe and I installed all my old apps except for Android Wear.. my battery is fine now!
  5. koncek
    Donut Feb 7, 2018
    OK, I will try doing this and will give feedback hopefully today evening. Thanks!
    Josiah1231 likes this.
  6. pawan jakhar
    Cupcake Feb 7, 2018
  7. DJSubterrain
    Ice Cream Sandwich Feb 7, 2018
    DJSubterrain , Feb 7, 2018 :
    If you are losing a lot of battery life it might be due to a wakelock (i.e. something keeping the phone awake when it should be sleeping), try a wakelock app to investigate before blaming the build. Also try clearing your caches in recovery too.
    Some wakelock apps might require root access to check properly :
    https://play.google.com/store/search?q=wakelock
  8. staycalm
    Froyo Feb 7, 2018
    staycalm , Feb 7, 2018 :
    Am I the only one experiencing battery drain issues after installing this update? I used to get 6h SOT on 5.0.1 and now I get 4.5h SOT using about 99% of the same apps.
    srie and Guilherme Fontes like this.
  9. gmavridis
    Froyo Feb 7, 2018
    gmavridis , Feb 7, 2018 :
    Keep in mind that the lower cpu speed has been icreased from 300 MHz to 518 MHz. The 300, 364 and 441 MHz are no longer usable. We are waiting for a reply, I hope not in vain...
    See also:
    https://forums.oneplus.net/threads/cpu-idle-clock-speed-went-up-on-5-0-2.766944/
    https://forums.oneplus.net/threads/...nt-way-up-on-5-0-2-and-ob5-not-solved.775569/
    https://forums.oneplus.net/threads/cpu-overcloking-in-idle-state.773977/
    swa100 and staycalm like this.
  10. akuadi
    Froyo Feb 7, 2018
    akuadi , Feb 7, 2018 :
    i think OP Dev should upgrade to oreo 8.1 for more stability.. even google dont use 8.0 anymore that causing so many problems.. just an opinion..
  11. Guilherme Fontes
    Honeycomb Feb 7, 2018
    Guilherme Fontes , Feb 7, 2018 :
    Hey again! After optimizing Android Wear app the battery seems to be much better!! Thx for that!!! And I have searched for a bit and found that the problem could he because of cloud sync. Try to disable that and check if battery is good. That has done the trick for me, I guess( I am going to check my battery for a week or so to really know if the battery drain is better.) But Android 8.0 has some battery draining issues by it self. Even Google launched 8.1 to correct some stuff.
    Josiah1231 and srie like this.
  12. G_adarshnholla_adi_MdGw
    Froyo Feb 7, 2018
    G_adarshnholla_adi_MdGw , Feb 7, 2018 :
    after recent updates My battery is draining fast, so many background system application consuming battery and data and in door pictures is coming very bad after the recent updates color saturation is very bad. if anyone zoom the pic after taking pic clarity of the pic is coming like some low end phone 2mp camera pics kind off. Is anyone facing same issue as mine???????. I think OnePlus Team has to look into this matter seriously
  13. flyingdad
    flyingdad , Feb 7, 2018 :
    Don't think so. Use the search function, read previous posts. Go to battery settings and set Whatsapp not to be optimized. Notifications will work properly.
  14. flyingdad
    Whatsapp needs not to be battery optimized to work properly in the background. Already mentioned a hundred times ....,
    MikeG247 likes this.
  15. Josiah1231
    I'm glad that worked out! and I'll look into the cloud sync too! thanks for the info
    Guilherme Fontes likes this.
  16. crzfyr
    Froyo Feb 7, 2018
    crzfyr , Feb 7, 2018 :
    it is not with the notification
    notification is working perfectly fine but it is not expanding
    couldn't use the quick reply option (not expanding)
  17. Deactivated User
    Feb 7, 2018
  18. K1518023996861
    Cupcake Feb 7, 2018
  19. vinodh_dasari
    Froyo Feb 7, 2018
    vinodh_dasari , Feb 7, 2018 :
    5.0.2 updated facing dailer issue .. I am unable to call anyone ,
    I have to restart my mobile to make a call
  20. K1518023996861
    Cupcake Feb 7, 2018
