428
OxygenOS 5.0.2 OTA for the OnePlus 5
  1. nsi34
    Eclair Feb 8, 2018
  2. Kavithaguru
    Donut Feb 8, 2018
  3. koolharshit7
    Froyo Feb 8, 2018
    koolharshit7 , Feb 8, 2018 :
    having heating issues...never had heating issues but after this update phone is heating both while Charing and using...
  4. flyingdad
    Ice Cream Sandwich Feb 8, 2018
    flyingdad , Feb 8, 2018 :
    After having wiped the system cache, look carefully at the applications battery optimization. Some applications need not to be optimized to notify properly. Investigate. Update all applications if needed and possible as well. Some applications may not be Oreo optimized yet. The ROM itself is OK.
  5. flyingdad
    Wipe cache as a minimum. Look at all settings carefully, especially at battery optimization. Update all applications if needed. And if necessary, factory reset. This ROM works fine for the vast majority of people. Myself I have no problems at all. Wifi and BT are connected h24, battery life is good, no bugs encountered. I clean installed 5.02 and erased everything when moving from beta 5.
    MikeG247 likes this.
  6. Guilherme Fontes
    Honeycomb Feb 8, 2018
    Guilherme Fontes , Feb 8, 2018 :
    Well, yesterday my battery seemed pretty good but today just woke up and lost 4% in almost an hour. And this is without actively using it! I am just hearing to some music with Bluetooth earbuds. Don't know if that's the reason for the phone not to enter in sleep. But that's one of the reasons, maybe... I will still wait for a week or so and check if this is a huge problem. One thing is for sure. The battery life on nougat was better!
  7. MosQa75
    Eclair Feb 8, 2018
    MosQa75 , Feb 8, 2018 :
    Hey oneplus team, please work on following as lot of people got below issues after update:
    1) improve camera/photo quality
    2) improve battery life
    3) EIS
    4) etc.
    I will stay on NOUGAT and wait for proper version which I beleive will be released soon.
    Thanks for your work.
    Rarinrob likes this.
  8. nsi34
    Eclair Feb 8, 2018
    nsi34 , Feb 8, 2018 :
    [QUOTE = "flyingdad, poste: 17759923, membre: 344423"] Après avoir effacé le cache système, examinez attentivement l'optimisation de la batterie des applications. Certaines applications n'ont pas besoin d'être optimisées pour notifier correctement. Enquêter. Mettez à jour toutes les applications si nécessaire et possible aussi. Certaines applications peuvent ne pas encore être optimisées par Oreo. La ROM elle-même est OK. [/ QUOTE]
    Thank you flyingdad. No optimisation at all on my OP5. All apps are up to date. I'm flashing back Open Beta 5 which worked perfectly
  9. A1512416697739
    Cupcake Feb 8, 2018
  10. adityabafana
    Eclair Feb 8, 2018
    adityabafana , Feb 8, 2018 :
    same thing happened with my OnePlus 5 after the recent update, the ringer of the phone goes silent even after every settings is normal on phone to ring when call comes. To fix this everytime u need to restart your cell. it's very very annoying
  11. Josiah1231
    Gingerbread Feb 8, 2018
    Josiah1231 , Feb 8, 2018 :
    damn. that was similar to my issue except my battery would drop 4% in like 20 minutes. why is the play store eating that much battery?
  12. Guilherme Fontes
    I updated a few apps in the morning. But it should change in a few hours. Right now is like this:
    The phone kinda went into sleep while I was in the classroom:
    I think doze is that thing in the developer options that you can activate so the phone controls background apps. But I am not really sure...
  13. Guilherme Fontes
    And! it just dropped to 72 now... LoL! I am not really liking this... it just wasted 3% while I was in classroom for 1hr and half. The app I am using to monitor the battery is getting the stats kind of right but it should have just lost like 1 %. That's what I saw on some videos. Tommorow I will try enabling Android Wear optimization again and will see if it's really it. But is weird because the app says Android Wear app has used just a bit of energy. Maybe something related to Bluetooth connection and not directly Android Wear... Oh and by the way! I gave root permissions to this app through an adb command so the stats that It is showing should be correct.
  14. Josiah1231
    I honestly don't know some of the apps that you have installed so maybe it could be one of those? I know with Android Wear even if it said it was only taking like 2% battery stuff was still going on in the background. I really don't take the battery usage breakdown seriously for that reason. if after the week it's still giving you a hard time I would do a hard reset. but nougat did have better life in general. I'm hoping they push out a battery optimization update soon.
    Guilherme Fontes likes this.
  15. Josiah1231
    it could be a root thing then.. that's one of the reasons I stopped rooting. it became too unreliable for performance and battery life.
  16. Guilherme Fontes
    No, I don't have root. I just gave permissions to this app. Root makes battery life even better.
    Josiah1231 likes this.
  17. I1517414177701
    Cupcake Feb 8, 2018
    I1517414177701 , Feb 8, 2018 :
    is it available for 3t
  18. Josiah1231
    granted I haven't rooted anything since the Galaxy s4 but just in my experience with that I don't really trust root so you might be right.. but yeah try the Android Wear optimization and if that doesn't work just do a hard wipe.. and my battery life is better than it was for sure but it's not nearly as good as it was a nougat. I could go almost two days easy before I updated.
  19. G_Rohan_Kumrawat_sPto
    Cupcake Feb 8, 2018
  20. Jillala_Sravan
    Jillala_Sravan , Feb 8, 2018 :
    Same here.bro.
    metaloid2k16 likes this.
