428
OxygenOS 5.0.2 OTA for the OnePlus 5
  1. Guilherme Fontes
    Honeycomb Feb 20, 2018
    Guilherme Fontes , Feb 20, 2018 :
    Battery continues really bad :/. I have already did a clean install of 5.0.2 and it got better but then it got worst again... Don't really know what is happening. Oh! And yeah, I already cleared cache. So Oxygen OS Oreo based version is really screwing up with the battery. I just the phone for a few mins and the battery percentage went down a bit. That's really bad.
    The attachment below shows my battery stats from 2 DAYS!
    when I got that good battery life I was in zones with very good network connection. Now I am on a island , maybe that's the issue. However before Oreo updates( in nougat) I got good battery life, so maybe that's an issue of Oreo.
    Deactivated User likes this.
  2. G_Vivek_Gulia_kHGC
    Gingerbread Feb 20, 2018
    G_Vivek_Gulia_kHGC , Feb 20, 2018 :
    mine fingerprint reader is not working properly. it works sometime and many a time it doesn't works. any solution please
  3. pratik.ranpariya
    Froyo Feb 20, 2018
  4. u1988
    Cupcake Feb 20, 2018
    u1988 , Feb 20, 2018 :
    Battery not stable , no sound ringtons or notification sounds..Gps not accurate.
    1+ knows about it for some times, any updates / replay from 1+ about it??
    The No sound are the biggest problem right now.
    Please 1+ support provide solutions.
    G_Viktor_Ermolov_uUmU likes this.
  5. G_Abhijeet_Patnaik_pnhl
    Eclair Feb 21, 2018
    G_Abhijeet_Patnaik_pnhl , Feb 21, 2018 :
    Sometime phone doesn't ring... Many apps are crashing and showing open again
  6. marcusskyfall
    Jelly Bean Feb 21, 2018
    marcusskyfall , Feb 21, 2018 :
    Try the following
    Boot the phone into recovery mode and clear the cache.
    1. Power off phone.
    2. Power on phone whilst holding down the volume down button (this takes slightly longer to react than you would expect and after the initial splash screen goes blank for a slightly un-nerving amount of time. But just wait).
    3. Enter the PIN/Password you use to unlock the phone when prompted.
    4. Choose a language.
    5. Choose "Wipe data and cache" (don't worry this is only a path to a submenu, it won't delete your data).
    6. Choose "Wipe cache" (IMPORTANT - MAKE SURE YOU DON'T TAP ERASE EVERYTHING).
    7. It will confirm that you have selected clear cache and ask you to say YES.
    8. When it says success choose "Reboot"
    sachkharb and u1988 like this.
  7. abhik_44
    Donut Feb 22, 2018
    abhik_44 , Feb 22, 2018 :
    phone works fine with no muting of ringtone however battery is not lasting more than 12 hours before the update it used to last atleast 20-24 hours....with the usage I have
  8. G_Abdul_Askar_IcXx
    Cupcake Feb 22, 2018
    G_Abdul_Askar_IcXx , Feb 22, 2018 :
    once took upgrade of it. I'm experiencing ringer sound not coming intermittently.
    once reboot the Mobile it's getting fixed. why pls suggest..
  9. Suraj gurav 007
    Ice Cream Sandwich Feb 22, 2018
  10. Malhotra260399
    Malhotra260399 , Feb 22, 2018 :
    This update has been the worst. I used to respect OnePlus for not rolling out untested updates but this is just disappointing. The camera stops working. Apps stop responding particularly snapchat. The screen blacks out.
    sanket.t03 likes this.
  11. jstiggie
    Honeycomb Feb 22, 2018
  12. G_Avee_B_Xaxb
    Jelly Bean Feb 22, 2018
    G_Avee_B_Xaxb , Feb 22, 2018 :
    it's been like this since the OP3 for many users after update, you can consider this on your next mobile purchase
  13. Sridhar Ananthanarayanan
    Lollipop Feb 22, 2018
    MikeG247 and Malhotra260399 like this.
  14. Malhotra260399
    thats just one of the issues. If you don't want to contribute then please don't post here.
  15. camohan
    Marshmallow Moderator Feb 22, 2018
    camohan , Feb 22, 2018 :
    Thread merged. You can get help here.
  16. Suraj gurav 007
  17. G_Abhijeet_Patnaik_pnhl
    Eclair Feb 22, 2018
    G_Abhijeet_Patnaik_pnhl , Feb 22, 2018 :
    Bro... I already have done it... Even after that problem continues
  18. j0k3rip
    Gingerbread Feb 22, 2018
    j0k3rip , Feb 22, 2018 :
    Did you try factory reset?
  19. j0k3rip
    Anyone facing incoming call ringtone issue pls try this:
    1. Put Alert slider to "Do not disturb"
    2. Go to Settings / Alert slider / Do not disturb
    3. Change Calls to "From anyone"
    4. Change Messages to "From anyone".
    5. Then put alert slider back to "Ring"
    Let me know if it works. If not then sorry. Cheers
  20. P1517674712460
    Donut Feb 22, 2018
    P1517674712460 , Feb 22, 2018 :
    I tried via opera but there is no download been shown for update except in US region.. Also it's the same update for 35mb shown but this is also get failed instantly when I try to download the update..
