417
OxygenOS 5.0.3 OTA for the OnePlus 3 & 3T
  1. T1527704105623
    Cupcake May 30, 2018
    T1527704105623 , May 30, 2018 :
    my finger scanner is working and face unlock feature is beyond security parameters. it's for fun to unlock.
    the real issue is Mirai bot or attack that can monitor you using ur frot cam.
  2. T1527704105623
    yesss my parallel app is not working, face unlock disable password lock. don't update.. you are good with your current version. don't update. I'm already facing issues.
  3. T1527704105623
    yup had same issue. full of bugs update
    Loukiack likes this.
  4. oshrn
    Eclair May 30, 2018
    oshrn , May 30, 2018 :
    I got a notification that my phone needed to upgraded today, however, I'm holding off on it because of the previous issues I had with the last update.
    Has anyone experienced any issues so far, or has it been smooth sailing?
  5. 4384726
    Donut May 30, 2018
  6. Jaitra Sen
  7. gokulkarthick
    gokulkarthick , May 30, 2018 :
    Lot of issues after updating
    1. Battery standby low
    2. Parallel apps not working
    3. Notification light unable to change
    These are major
    Kindly fix these ASAP 1+ team
    Thank you.
    KedielSensei and J1508190968061 like this.
  8. Cervantes
    Lollipop Moderator May 30, 2018
    Cervantes , May 30, 2018 :
    Please, You check the forum before opening a new thread
    Thread merged
  9. G_Ram_Madurai_LPDd
    Donut May 30, 2018
  10. Siva_Praneeth_PS
    Froyo May 30, 2018
    Siva_Praneeth_PS , May 30, 2018 :
    Backup ur data & HARD RESET (Wipe/cache data) ur mobile.. That's the best thing..
    G_James_Taaffe_MYxD likes this.
  11. rrray
  12. Ashish_K.
    Eclair May 30, 2018
    Ashish_K. , May 30, 2018 :
    it has arrived in India. don't rely on notification, check manually from settings. even i did not get any notification as such, but when i manually checked for updates it showed as available. This was at 6.30 pm on 30.05.2018
  13. Ashish_K.
    Eclair May 30, 2018
    which SIM service you using sir?
  14. Tu_mamita
    Tu_mamita , May 30, 2018 :
    3T affirmative
  15. G_James_Taaffe_MYxD
    Ice Cream Sandwich May 30, 2018
    G_James_Taaffe_MYxD , May 30, 2018 :
    bc you have hardware buttons, also all the ppl with problems, have u tried cache clear / factory reset?
    f00tbaLL likes this.
  16. arturjot
    Eclair May 30, 2018
    arturjot , May 30, 2018 :
    Just updated my OP3. Partial update failed, but complete update worked. So far everything seems fine.
  17. johnn_91
    Eclair May 30, 2018
    johnn_91 , May 30, 2018 :
    just updated, awesome, thanks to all the team. Hope this update not to be the last one
  18. Onji
    Gingerbread May 30, 2018
    Onji , May 30, 2018 :
    Good for you! Must feel nice, right?
  19. gam.artistic
    Kunlan likes this.
  20. mohammedazher
    Donut May 30, 2018
    mohammedazher , May 30, 2018 :
    thank you OnePlus for updated version of Oxygen 5.0.3 for 3t users face unluck added security patche also thank you
