417
OxygenOS 5.0.3 OTA for the OnePlus 3 & 3T
  1. kpoyser
    Gingerbread Jun 8, 2018
    kpoyser , Jun 8, 2018 :
    there's no new camera app. it's still version 1.5. has been for 6 months. so the features you think are new have always been there
  2. F_Arvind_Kumar_eEcK
    Cupcake Jun 9, 2018
    F_Arvind_Kumar_eEcK , Jun 9, 2018 :
    yes It's hardware problem, please tell me how to fix this?
  3. C1508926227327
    Cupcake Jun 9, 2018
    C1508926227327 , Jun 9, 2018 :
    facing issued like low volume in call , battery draining fast , battery saver doesn't decrease performance any one facing this and have you got any solution for these ?
    G_vadtya_Hyshwar_coim likes this.
  4. PTuT
    Jelly Bean Jun 9, 2018
    PTuT , Jun 9, 2018 :
    The best way is to contact support. They may repair it free of charge. Some people played with small magnets or shaking but final solution is to replace the module.
    F_Arvind_Kumar_eEcK likes this.
  5. Aeron
    Gingerbread Jun 9, 2018
    Aeron , Jun 9, 2018 :
    Apparently its pretty different for each user.
    From my side I can tell that Battery life is slighlt better, no heating present and phone itself is a bit more responsive that before. On the other hand I have cleared cache immediatelly after upgrade to get rid of leftovers and dont have Battery Draining apps (like Facebook, I hate that app).
    Anyway Its really really different for each user. Everyone is using phone for different things.
    If you have time you can always try and return back to previous version. Though its not that easy for all people to play with ROMs.
  6. noquarter
    Lollipop Jun 9, 2018
    noquarter , Jun 9, 2018 :
    Merged with main thread
    C1508926227327 likes this.
  7. ujjaval_moradiya
    Cupcake Jun 9, 2018
  8. buruaden786
  9. camohan
    Marshmallow Moderator Jun 9, 2018
    camohan , Jun 9, 2018 :
    thread merged.
  10. ambarish16
    Froyo Jun 9, 2018
  11. Rama gangadhar
    Donut Jun 9, 2018
  12. M1521377798830
    Cupcake Jun 9, 2018
  13. Dr.SRJ
    Donut Jun 9, 2018
    Dr.SRJ , Jun 9, 2018 :
    After the update Everything is fine other than the battery. Battery Life reduced and not as efficient as i had with the stable nougat...[e]1f621[/e] Waiting for next stable update
  14. swathinag3686
  15. Sun90
    Starting Point Expert Jun 9, 2018
    Sun90 , Jun 9, 2018 :
    It would be the same case even before the update too ( which you might have failed to observe).
    Nothing alarming to worry about.
    And there is a dedicated thread for the update use it to post.
    noquarter likes this.
  16. swathinag3686
    swathinag3686 , Jun 9, 2018 :
    it is consuming battery
  17. noquarter
    Sun90 likes this.
  18. Sun90
    Post the battery stats.
  19. swathinag3686
  20. Sun90
    swathinag3686 likes this.
