417
OxygenOS 5.0.3 OTA for the OnePlus 3 & 3T
  1. G_James_Taaffe_MYxD
    Ice Cream Sandwich Jun 23, 2018
  2. K_S_R
    Gingerbread Jun 23, 2018
    K_S_R , Jun 23, 2018 :
    Even though I have vibrate during call enabled, my phone doesn't vibrate. Even in the slider banner it just shows as ring rather than Ring(vibrate). Am I missing something here?
  3. jaivaghela
    jaivaghela , Jun 23, 2018 :
    Terrible focus problems on the OP3 & OP3T. Difficult to focus on the subject even when tapping on it. Hope its only a software issue and not a hardware issue. Devs please look into this.
    Arbingr8 likes this.
  4. Andrei R.
    Andrei R. , Jun 23, 2018 :
    It doesn't "show" blured pictures. It captures them because of the poor quality of the sensor, the software is forced to crank up the exposure time. Which in shaky hands or moving subjects can lead to this blur (especially in darker scenarios). I know it's not a good camera, but learn to live with it and use it. With other software and a stable hand, my results are solid enough for me. ;)
  5. BuenoAmigo
  6. ghostofcain
    Marshmallow Jun 23, 2018
    ghostofcain , Jun 23, 2018 :
    Outside of apple, care to tell me an OEM who doesnt? Btw quite how does this relate to latest stable OP3(T) release?
    Sun90 likes this.
  7. lkosova
    lkosova , Jun 23, 2018 :
    What other software are you using...?? Thx
  8. dimovkster
    kdx12, Ozesh and lkosova like this.
  9. G_SACHIN_KAMBLE_nbgH
    Eclair Jun 24, 2018
    sparsh7777 likes this.
  10. Andrei R.
    Ice Cream Sandwich Jun 24, 2018
    Andrei R. , Jun 24, 2018 :
    Gcam. Search on XDA or even this forum
    lkosova likes this.
  11. KirillFry
    Cupcake Jun 24, 2018
  12. ghostofcain
    Marshmallow Jun 24, 2018
    Sun90 likes this.
  13. I1529833384664
    I1529833384664 , Jun 24, 2018 :
    my phone gets heated up inspite of no applications running in the background. I have to charge my phone twice a day. I got this phone in the month of September 2017. please advise
  14. K1520421625645
    K1520421625645 , Jun 24, 2018 :
    Dear O+ Community,
    I had a wifi operation problem. It is not stabile, I mean hardly find conncetion and always lost is. The speed very low as well. I did not any change on the phone. Local router tested, it works properly. Could you make and software update asap pleas. It very effect my daily work. The hotspot works perfectly, so I guess it is not a hardware issue. last Op on the device. Thank you.
  15. LakshayDhiman
    Honeycomb Jun 24, 2018
    LakshayDhiman , Jun 24, 2018 :
    everyone facing same issues...u can try resetting the phone ...mine doesn't works differently even after resetting
    I1529833384664 likes this.
  16. RASTAVIPER
    Jelly Bean Jun 24, 2018
    RASTAVIPER , Jun 24, 2018 :
    Who told you that 4hours of SOT is not good, especially if you are using 4G??
    It seems that you don't know some basic things.
  17. nope1nope
    nope1nope , Jun 24, 2018 :
    I am not sure about you but that SOT is pretty good. On my OnePlus 3 i am getting around 3:30 hours SOT. Which last me a day, I have to charge at evening for using phone in night which is fine. Yup the battery capacity is not as good as before but it is expected from a two year old phone. I don't think software update will improve this drastically.
    jnsson and C1529986359919 like this.
  18. lkosova
    lkosova , Jun 24, 2018 :
    This has to be subject to your location. I will just guess India...... It would be nice if people stated their location since I have none of that in the States I also traveled to Germany and Iceland and it was perfect there.
  19. Arbingr8
    Arbingr8 , Jun 24, 2018 :
    True camera has problem focusing...
