417
OxygenOS 5.0.3 OTA for the OnePlus 3 & 3T
  1. Romeo_Scurtu
    Cupcake May 28, 2018
    Romeo_Scurtu , May 28, 2018 :
    Try to locate the file and add the suffix .pdf
  2. Dresa91
    User of the Year 2016; Most Active User 2020 May 28, 2018
    Dresa91 , May 28, 2018 :
    ah ok. this might be a reason. Did not know that
  3. PTuT
    Jelly Bean May 28, 2018
    PTuT , May 28, 2018 :
    Usually, in the past, I had no issue of getting it via VPN. Now, it's a no go. Few others mentioned that. Well I was more (or less) patient for last 5 months so I can wait little bit longer. [e]1f60f[/e]
  4. Balaji ln
  5. kumarharsh8
    Gingerbread May 28, 2018
    kumarharsh8 , May 28, 2018 :
    If you are on 5.0.2 roll back to 5.0.1 and the check via a vpn aap, it worked for me.
  6. G_Anirudh_Sadhu_sBmE
  7. Karthi06
    Donut May 28, 2018
  8. G_Zaheen_Xakir_tkaJ
    Eclair May 28, 2018
  9. Dwij_Mewada
    Froyo May 28, 2018
  10. Loukiack
    Honeycomb May 28, 2018
    Loukiack , May 28, 2018 :
    ok once again battery issues.....op3 lost 4% of battery in ten minutes just been on viber with wifi.
  11. brokenhearti
    Donut May 28, 2018
  12. aakash0606
    aakash0606 , May 28, 2018 :
    Oxygen Updater from Play Store. then system updates>add from local storage
    T1521678155981 likes this.
  13. Arjunguptaa
  14. svchong
    svchong , May 28, 2018 :
    My 3T , after update to 5.0.3, the parallel whatsapp always crash whenever i press the send button.
    Is that any fix of that?
    It is very disturbing ,crash message always pop up, asking reopen app.
    Help
  15. Nikhil Bacha
    Froyo May 28, 2018
  16. Nikhil Bacha
    Froyo May 28, 2018
    Nikhil Bacha , May 28, 2018 :
    try to do factory reset it may work..
  17. PTuT
    I am on 5.0.1.
  18. Rui Delgado
    Froyo May 28, 2018
    Rui Delgado , May 28, 2018 :
    I must say this is one of the best updates... The face unlock is pretty fast and reliable, the battery have been improve a little (still early to say but should improve a bit more), fast navigation as usual and no problem till now (in 5.0.1 have 3/4 little bugs, now is solve). Happy with this. Thanks Oneplus
  19. Arjunguptaa
    Arjunguptaa , May 28, 2018 :
    Bro I already did that
  20. Arjunguptaa
    Nikhil Bacha
    when did you get the update, are you in india?​
    I updated it yesterday
    Yes im in India
