674
OxygenOS 5.0.3 OTA for the OnePlus 5T
  1. Spetch
    Eclair Feb 4, 2018
    Spetch , Feb 4, 2018 :
    I live in Canada and I haven't received it. I likely won't install it. I haven't even installed 4.7.6 yet because of the reviews.
    What's the hurry?
  2. K1517711311910
    Cupcake Feb 4, 2018
    K1517711311910 , Feb 4, 2018 :
    Can you elaborate what exact issue you referring to?
  3. Dineshkarthik1122
    Donut Feb 4, 2018
  4. polisettysd
    Gingerbread Feb 4, 2018
    polisettysd , Feb 4, 2018 :
    Hello there...
    You will continue to get the beta updates in future much before that the others.
    Yes if u want you can get back to regular stable updates but the process may need you to do a clean install of the total OS.
    Search the web and I am sure u will find the step by step process there and its easy.
    Keep Rocking
    Never Settle
    jugegamo likes this.
  5. Cervantes
    Lollipop Moderator Feb 4, 2018
    Cervantes , Feb 4, 2018 :
    Thread merged
    Please read first post
  6. polisettysd
    If u r okay try Oxygen Updater from Google app store and this will get u the update without any extra settings.
    I am a user of oxygen updater right from OP2 and u can trust that app like many of us on this forum has trusted.
    Pls post that u got the update through Oxygen Updater.
    I guarantee that in under 60minutes, u will be running on OREO Based Oxygen.
    Keep Rocking
    Never Settle
    G_Costin_O_oHpX likes this.
  7. jugegamo
    jugegamo , Feb 4, 2018 :
    Now that's what I needed to understand. Thank you very very much for the quick answer. I decide to stay in the beta program until OnePlus dictates it's over. Best regards from Mexico.
  8. polisettysd
    jugegamo
    Now that's what I needed to understand. Thank you very very much for the quick answer. I decide to stay in the beta program until OnePlus dictates it's over. Best regards from Mexico.​
    My Dear friend today its Oreo Beta tomorrow its will be another so u will not have an opportunity to come out of beta then as there will always be a new beta update coming up every now & then.
    Instead if its okay switch between stable and beta for a month just think to enjoy the best of both worlds.
    Keep Rocking
    Never Settle
  9. jugegamo
    Yes I understand that. For now i will stay in the Beta program. Thank you.
  10. lakhan rathi
    Donut Feb 4, 2018
  11. K1517411038608
    Cupcake Feb 4, 2018
  12. F_Varun_Jain_sJaH
    Eclair Feb 4, 2018
  13. satyendra288
    Eclair Feb 4, 2018
  14. F_Varun_Jain_sJaH
    Eclair Feb 4, 2018
    F_Varun_Jain_sJaH , Feb 4, 2018 :
    Use OnePlus updater from playstore. I even got the 39mb Kernel updated 5.0.3 today.
    satyendra288 likes this.
  15. Suraj gurav 007
    Ice Cream Sandwich Feb 4, 2018
  16. HarshThanvi
    HarshThanvi , Feb 4, 2018 :
    now since new update is out try opera vpn and connect to canada and u'll instantly get updates
  17. HarshThanvi
  18. Dhruv Mepani
    Cupcake Feb 4, 2018
    Dhruv Mepani , Feb 4, 2018 :
    i am able to download from Germany using 'Turbo VPN' app. you can find it on playstore.
  19. sumitranjan.panda
    sumitranjan.panda , Feb 4, 2018 :
    I was trying for that when the update was getting uploaded. So it wasn't available.
    I am on the update now.
    Thanks for the suggestion.[e]1f60a[/e]
  20. O1516731164158
    Eclair Feb 4, 2018
