674
OxygenOS 5.0.3 OTA for the OnePlus 5T
  1. Pratheekh Chandra
    Cupcake Feb 4, 2018
  2. rahild
    Eclair Feb 4, 2018
    rahild , Feb 4, 2018 :
    1) download Opera VPN from play store
    2) change the country to Canada (you can try Germany if Canada does not work!!)
    3) turn on activation guard
    4) check for updates in settings
    5) you will see the new 5.0.3 Oreo update!!
    6) download and enjoy
    p.s:- I downloaded this yesterday and it works great. love it
  3. shanrock123
    Cupcake Feb 4, 2018
    shanrock123 , Feb 4, 2018 :
    how to turn on activating guard?
  4. Français OP5T
    Froyo Feb 4, 2018
    Français OP5T , Feb 4, 2018 :
    hahahahahaha
    ArmataReloaded likes this.
  5. Français OP5T
    Froyo Feb 4, 2018
  6. shanrock123
    Cupcake Feb 4, 2018
    eye842 likes this.
  7. R1517062234839
    Eclair Feb 4, 2018
    R1517062234839 , Feb 4, 2018 :
    awesome thought!
    rahulsipu likes this.
  8. Rebel242
    Froyo Feb 4, 2018
    Hydra Bob likes this.
  9. DealWithIt674
    Gingerbread Feb 4, 2018
    DealWithIt674 , Feb 4, 2018 :
    Just download "Oxygen updater" from PlayStore and follow the steps!!! Vpn didn't work for me, so I used this. it worked Perfectly!!
  10. jbc98b
    Ice Cream Sandwich Feb 4, 2018
    jbc98b , Feb 4, 2018 :
    Oreo update????????????????????
    Download it!!!!!!!!!!!!!!!!!!!
    Shut up about it!!!!!!!!!!!!!!
    Nick 59 likes this.
  11. Ed_88
    Honeycomb Feb 4, 2018
    Ed_88 , Feb 4, 2018 :
    no issues here whatsoever, both on 5.0.2 and 5.0.3.
    then again I'm in the habit of doing a full data wipe (factory reset) when upgrading a major android version.
    maybe try that?
  12. Nick 59
    Marshmallow Feb 4, 2018
  13. varma246
    Lollipop Feb 4, 2018
    varma246 , Feb 4, 2018 :
    Oreos already upgraded , they have lights now. See....
    Hydra Bob and eye842 like this.
  14. Paschfire
    KitKat Feb 4, 2018
  15. serialtoon
    Froyo Feb 4, 2018
    serialtoon , Feb 4, 2018 :
    Hey thanks for the response. I have the OTA they posted yesterday. Its about 1.6GB in size. Time to wipe! Thanks
    Joey463 and ruhela786 like this.
  16. Abhishekkhilari
    Cupcake Feb 4, 2018
    Abhishekkhilari , Feb 4, 2018 :
    Finally Installed it [e]1f618[/e] Thanks! OnePlus for Oreo Update[e]1f44f[/e][e]1f44f[/e][e]1f44f[/e]
    For those Indian User who are still searching for the OTA update please refer below steps
    1. Install Opera VPN through playstore.
    2. Open it and select Canada as ur region.
    3. Then go to settings --- System updates --- click Check for updates.
    there you go....u would be able to see the latest Oxygen OS version 5.0.3 / Android Version (Oreo 8.0.0)
    Download it and Install...!!!
  17. T1515945146834
    Eclair Feb 4, 2018
    T1515945146834 , Feb 4, 2018 :
    any improvement from previous one?
  18. Waveform Modifier
    Waveform Modifier , Feb 4, 2018 :
    Yeah, you not using it. Don't download it, you will break it.
  19. T1515945146834
    Eclair Feb 4, 2018
    what do you mean bro
  20. fidus62
    Jelly Bean Feb 4, 2018
    fidus62 , Feb 4, 2018 :
    Lol
