674
OxygenOS 5.0.3 OTA for the OnePlus 5T
  1. kharwalsumit
    Cupcake Feb 7, 2018
    Nits23 likes this.
  2. Nits23
    Cupcake Feb 7, 2018
  3. dustupajisk
    Gingerbread Feb 7, 2018
    dustupajisk , Feb 7, 2018 :
    did you factory reset first? then applied the update.
    if not then it is the proper way.
  4. Mahesh_Reddy_K
    Cupcake Feb 7, 2018
    Mahesh_Reddy_K , Feb 7, 2018 :
    is there any change in the total memory after this update. earlier it was 52.67 GB
    now it's 56+ gb
  5. nick_k
    nick_k , Feb 7, 2018 :
    Do you have problems ?
    I read about fingerprint issues, unlock issues, app issues etc.
    The upgrade for me was smoother, even from my other phone, Nexus 5x.
  6. ɢноѕтΘпе
    Nougat Feb 7, 2018
  7. Matt 80
    Lollipop Feb 7, 2018
    Matt 80 , Feb 7, 2018 :
    5.0.2 had some bugs, 5.0.3 has fixed them. My battery life has improved greatly.
  8. kumaryashwin
    Jelly Bean Feb 7, 2018
  9. hellosibasis
    Cupcake Feb 7, 2018
  10. sabir.sayed
    Honeycomb Feb 7, 2018
    sabir.sayed , Feb 7, 2018 :
    I think u need to do the factory reset again and clear cache. Bcz for me it is smooth and fluid without any lag or issues but i did the clean format. As i was on beta.
    sijinjohn likes this.
  11. F_Srinivasa_Velagala_sQR
    Froyo Feb 7, 2018
  12. kaushik98
    Donut Feb 7, 2018
  13. kharwalsumit
    Cupcake Feb 7, 2018
    kharwalsumit , Feb 7, 2018 :
    I was not aware of this, will cache clear will help if done from recovery
  14. Roshidi
    Donut Feb 7, 2018
    Scherpenseel likes this.
  15. kermex
  16. 5T user
    Cupcake Feb 7, 2018
    5T user , Feb 7, 2018 :
    That's stereo typing mate. I would not encourage to point out this way of handling things.
  17. sarov
    Cupcake Feb 7, 2018
    sarov , Feb 7, 2018 :
    Hello Guys,
    Has anyone updated their OP5T to OxygenOS 5.0.3. I just want to make sure everything is fine before updating. I don't wanna be surprised by "My phone hangs after updating", "Battery draining like crazy", "Apps crashing" like problems after update ;)
    At present my OP5T works like a charm without any complaints and I want that experience to continue...!
  18. N1517550404672
    Cupcake Feb 7, 2018
  19. 5T user
    Cupcake Feb 7, 2018
    About the unlocking by finger print scanner, you don't have to worry on why vibration isn't working for u,as oreo update has made the vibration mode clear by default . However you can go to sound settings, there you need to turn on tap on touch option to get back the vibrating mode while unlocking by finger print. But this mode will also mean every touch u make on the phone will lead to vibration i guess.
  20. G_Akashi_(Raúl_Gómez)_Sg
    Cupcake Feb 7, 2018
    G_Akashi_(Raúl_Gómez)_Sg , Feb 7, 2018 :
    I've updated it and I didn't have any battery issues, though I got a better battery life lmao
    Oats17 likes this.
