674
OxygenOS 5.0.3 OTA for the OnePlus 5T
  1. dhopmans
    Honeycomb Feb 7, 2018
    dhopmans , Feb 7, 2018 :
    Install Beta 3 instead of Official Build. Then you can use gestures.
  2. Mohta.am
    Gingerbread Feb 7, 2018
    Mohta.am , Feb 7, 2018 :
    i phone gesture not in official ota update in beta testing after all bug fix then OnePlus give us
  3. XOVY
    XOVY , Feb 7, 2018 :
    Just installed, weird zoom in /out effect on screen rotating...
  4. Idanm1908
    Cupcake Feb 7, 2018
    Idanm1908 , Feb 7, 2018 :
    For now i noticed battery drain rate and a problem with gps, had to restart phone for waze to connect to gps servers successfuly
  5. Abhi Rulesz
    Cupcake Feb 7, 2018
    Abhi Rulesz , Feb 7, 2018 :
    I have deleted the Ota folder... Next what??
  6. 5T user
    Cupcake Feb 7, 2018
    5T user , Feb 7, 2018 :
    So far i have faced little glitch with unlocking by finger print scan which then i figured how to resolve it. Apart from this things have been going good with new Oreo update.
    Cheers!
  7. Abhi Rulesz
    Cupcake Feb 7, 2018
    Will it works after downloading it again..... I have tried twice previously....
  8. h_kashyap
    Jelly Bean Feb 7, 2018
    h_kashyap , Feb 7, 2018 :
    Now go to "System updates" again, download & install.(try only via WiFi or mobile network, don't switch in the middle).
    If this fails, click on below link, download. Next swtich off phone, go to recovery, locate the downloaded zip, install it, wipe cache in recovery itself, reboot.
    http://downloads.oneplus.net/oneplus-5t/oneplus_5t_oxygenos_5.0.3
  9. md_rayan
    Cupcake Feb 7, 2018
    md_rayan , Feb 7, 2018 :
    Upgraded to Oreo an hour ago and same here. No more vibration/haptic feedback when unlocking the phone through fingerprint scanner. Nor does it work when unlocking certain apps through OnePlus's in-built app locker. This is a big issue for me.
    No, I don't wanna enable vibrate on tap as I do not want every touch lead to vibration.
    OnePlus need to give an option to toggle screen unlock vibration on/off when using fingerprint.
    AshwaniNarula likes this.
  10. Mahmoud Mahafdah
  11. Paul_W_
    Paul_W_ , Feb 7, 2018 :
    Smooth update. Not a lot of visible changes. I'm not quite sure why there was all the hysteria about getting this update early.
  12. P1513674419821
    Eclair Feb 7, 2018
  13. Assermoussa
    Cupcake Feb 7, 2018
  14. PokiX
    PokiX , Feb 7, 2018 :
    I haven't got a problem.
    The best is to try by yourself. Nobody has the same usage, apps, expectations, ..
    The good thing with Android is that it's very easy to revert back if you're not happy.
    Mahmoud Mahafdah likes this.
  15. Prats21
    Cupcake Feb 7, 2018
  16. B1509655603072
    Cupcake Feb 7, 2018
  17. premvinay
    Eclair Feb 7, 2018
    kshail3 likes this.
  18. Singadi.Rajesh Kumar
    Cupcake Feb 7, 2018
  19. youbi
    Marshmallow Assistant Head Moderator Feb 7, 2018
    youbi , Feb 7, 2018 :
    Threads merged, no need to create new ones when we already have an official one to talk about the update. ;) If all did that we would just end with a cluttered forum that was impossible to use. :( Next time please check the pinned threads before creating a thread about an update, you will surely find the existing thread there.
    Go ahead, the battery is actually better for most people. ;)
    The gestures for now are only in the beta, and the double tap in power button doesn't work in India because of the SOS regulations you have there.
    You just need to check this thread. ;)
  20. dionisdei
