674
OxygenOS 5.0.3 OTA for the OnePlus 5T
  1. Deactivated User
    Feb 8, 2018
  2. poojapalvi
    Cupcake Feb 8, 2018
    poojapalvi , Feb 8, 2018 :
    go to settings >click on system updates (2nd last option) > check for update ...
  3. T1518064869602
    Cupcake Feb 8, 2018
    T1518064869602 , Feb 8, 2018 :
    The headset volume does sound lower. If it's done to conform to European voltage regulations, can the change be reverted for India?
    Also, anybody else seeing a faster battery drain? It isn't an issue but seems like the battery life is a wee bit lower than nougat.
  4. mohitjohri
    Donut Feb 8, 2018
    mohitjohri , Feb 8, 2018 :
    if I understood you correctly, you are not able to see the Oreo update again message.
    Go to settings -->system updates--> check for updates
    You will get the update ..!
  5. ruhela786
    Ice Cream Sandwich Feb 8, 2018
    ruhela786 , Feb 8, 2018 :
    +1 I'm also facing the exact issue.
  6. rhlkashyap41
    Cupcake Feb 8, 2018
  7. Q1515168454115
    Cupcake Feb 8, 2018
    Q1515168454115 , Feb 8, 2018 :
    Hi
    yesterday I installed updates on my phone after that I can't search any contact from my contact list please help me.
    regards
    sandeep
  8. Mohta.am
    Gingerbread Feb 8, 2018
    Mohta.am , Feb 8, 2018 :
    clear cache data and reboot your device you are not facing this issue.
  9. Q1515168454115
    Cupcake Feb 8, 2018
  10. Mohta.am
    Go to settings search storage s memory tap on you find cache data clear it and reboot your device
  11. remambian
    Donut Feb 8, 2018
    remambian , Feb 8, 2018 :
    What does the additional feature in the updated version of launcher, weather app, file manager and gallery ???
  12. Q1515168454115
    Cupcake Feb 8, 2018
  13. mmedalwar
    Cupcake Feb 8, 2018
  14. Chiraggreat
    Cupcake Feb 8, 2018
    Chiraggreat , Feb 8, 2018 :
    Is oreo update safe, as oreo update on one plus 3 was disastrous with many bugs and at end had to reset to factory setting loosing on all precious data.
  15. G_Darius_Foodei_xmYJ
    Froyo Feb 8, 2018
    G_Darius_Foodei_xmYJ , Feb 8, 2018 :
    it's the same [e]1f602[/e]I wouldn't advise to update now wait till 5.0.4 rolls out in a week or less and then download.
  16. Mohta.am
    Go to settings search storage s memory tap on you find cache data clear it and reboot your device you are not facing battery issue
  17. CarlosRod35
    Eclair Feb 8, 2018
  18. sresham60
    Cupcake Feb 8, 2018
    sresham60 , Feb 8, 2018 :
    After updating facing apps crashing and hanging issue battery draining fast need to fix the version.
  19. veda008
    Donut Feb 8, 2018
  20. Mohta.am
    sresham60
    After updating facing apps crashing and hanging issue battery draining fast need to fix the version.​
    are you on 5.0.3 version
