674
OxygenOS 5.0.3 OTA for the OnePlus 5T
  1. kteveler
    Cupcake Feb 10, 2018
    kteveler , Feb 10, 2018 :
    Really factory reset? or is that another joke?
    either way... works for me because I literally Justin set this 5t up. been sitting on it awhile because I have setting up new phones.
  2. kteveler
    are you 5 or 5T?
  3. billdakoutros
    Eclair Feb 10, 2018
  4. Harry d best
    Froyo Feb 10, 2018
  5. Bazz7777777
    Froyo Feb 10, 2018
    Harry d best likes this.
  6. Harry d best
    Froyo Feb 10, 2018
    Harry d best , Feb 10, 2018 :
    s 5.0.3 & 5.0.3 beta 3 s different??
  7. Bazz7777777
    Froyo Feb 10, 2018
  8. billdakoutros
    Eclair Feb 10, 2018
  9. Harry d best
    Froyo Feb 10, 2018
    ok thanks for the information how to find that my device s beta 3 version r not
    naeem.63 likes this.
  10. Harry d best
    Froyo Feb 10, 2018
  11. naeem.63
    Gingerbread Feb 10, 2018
    naeem.63 , Feb 10, 2018 :
    setting-about phone- oxygen version. if it is written 5.0.3 then its stable if its written 5.x x beta then its beta
  12. billdakoutros
    Eclair Feb 10, 2018
    billdakoutros , Feb 10, 2018 :
    its just an expression that is used for official massive upgrades
  13. Harry d best
    Froyo Feb 10, 2018
    ok thanks brother so mine s 5.0.3 only I'm not a beta version
  14. Harry d best
    Froyo Feb 10, 2018
    ok if I have turn it on the OTA & download the update what will happen??
  15. Harry d best
    Froyo Feb 10, 2018
    is thr any options to change to beta version???
  16. billdakoutros
    Eclair Feb 10, 2018
    go to downloads.oneplus.net select your phone find and download the beta version from your pc then connect your phone and copy the zip file to your internal storage.After that put your phone to recovery mode by holding the power button and the volume down button until it gets you to recovery mode then select language after than select install from internal storage install the file and then reboot
    naeem.63 and Harry d best like this.
  17. Harry d best
    Froyo Feb 10, 2018
    ok thank-you so much
    naeem.63 and billdakoutros like this.
  18. yasii_leo
    yasii_leo , Feb 10, 2018 :
    what about the apps and data? sorry but new to this forum, might be a stupid question!
  19. elanglois
    Lollipop Feb 11, 2018
    elanglois , Feb 11, 2018 :
    I'm a glass half broken kind of guy. Eventually you'll drop the phone and the glass will break, so you are half-way there
    suresh@kvsk and Hydra Bob like this.
  20. Miguel Chakarji
    Donut Feb 11, 2018
    Miguel Chakarji , Feb 11, 2018 :
    I'm really disappointed with the new status bar because you can't see the available WiFi networks or the Bluetooth devices on the kind of tray it had before from the status bar, now if you want to switch to another WiFi network or manage your Bluetooth devices you have to press and hold the buttons and get out of the app you were in to the settings app.
    This is a step back one plus, I hope this gets fixed on the next update.
