674
OxygenOS 5.0.3 OTA for the OnePlus 5T
  1. NerdicEclipse
    Honeycomb Feb 14, 2018
    NerdicEclipse , Feb 14, 2018 :
    You will not get an update to stable when you're on the Beta channel but you will get any future beta updates. If you want stable channel, you have to flash to stable again manually.
  2. kayroccs
    Eclair Feb 14, 2018
    kayroccs , Feb 14, 2018 :
    I agree with point 2 also aptxHD isn't being activated anymore.
    patchasik likes this.
  3. dotdotjuan
    Froyo Feb 14, 2018
    dotdotjuan , Feb 14, 2018 :
    I miss the drop-down settings.
    for example, on Nougat under or next to wifi there was a down arrow to display and select the WiFi network right from there.
    post update, you have to hold down wifi then it takes you to the wifi setting
  4. G_Muthu_Raj_mVYe
    Cupcake Feb 14, 2018
  5. Y1518617345413
  6. Alecksander
    Ice Cream Sandwich Feb 14, 2018
  7. A1518623078078
    Q1513660855217 likes this.
  8. Q1513660855217
    Q1513660855217 , Feb 14, 2018 :
    Why there is a Security patch level for Dec 2017 pushed with 5.0.3 OTA update instead of giving a security patch level for Feb 2018?
  9. Razvan B.
    Gingerbread Feb 14, 2018
    Razvan B. , Feb 14, 2018 :
    I ask the same thing ... nobody reply
  10. satyendra288
    Eclair Feb 14, 2018
    satyendra288 , Feb 14, 2018 :
    After updating to Oreo, I'm facing following problems:
    1. Google assistant is not working (voice model)
    2. Phone is being hanged repeatedly at the time on unlocking.
    3. Sometimes network problems.
    anyone else facing any issue after update.
  11. assassin169
    assassin169 , Feb 14, 2018 :
    Battery backup is not upto the mark compared to nougat !! need to be customized in a more effective way!!!
  12. satyendra288
    Eclair Feb 14, 2018
  13. UmeshSailor
  14. Mahmoud Mahafdah
  15. MentalDraco
    Marshmallow Feb 14, 2018
    MentalDraco , Feb 14, 2018 :
    All updates have bugs, there is not one update on the planet that dose not have a bug.
  16. HonestSavage
    HonestSavage , Feb 14, 2018 :
    The Ram management is not good in oxygen os 5.0.3 oreo update ! ive cleared the cache also.. but its still cant hold 10-15 apps in the background! Apps automatically shutdown in the background after a while. In developers option "dont keep activities" is also disabled !
  17. HonestSavage
  18. MentalDraco
    satyendra288 likes this.
  19. satyendra288
    Eclair Feb 14, 2018
    screenshot is for 2nd point, phone is not responding
  20. Matt 80
    Lollipop Feb 14, 2018
    Matt 80 , Feb 14, 2018 :
    Some people will tell you it's great, others will tell you it sucks, i've had no issues with it personally. You just need to make a decision for yourself.
