674
OxygenOS 5.0.3 OTA for the OnePlus 5T
  1. macsenjose18
    Froyo Feb 1, 2018
    macsenjose18 , Feb 1, 2018 :
    that was part of beta 3. will be added in upcoming official oreo updates
  2. polisettysd
    Gingerbread Feb 1, 2018
    polisettysd , Feb 1, 2018 :
    Dear Friend download either a VPN app or the Oxygen Updater from the play store and u will get it instantly.
    Pls read a few posts in the forum and u will find all the solutions.
    Have a Great Day.
  3. rian.acca
    Cupcake Feb 1, 2018
    rian.acca , Feb 1, 2018 :
    sad i liked that. after updated oreo thats gone
  4. polisettysd
    Official Bro... Never Settle
  5. polisettysd
    Happy to hear bro. Have a great time
  6. bhaskar.kumar
    Cupcake Feb 1, 2018
    bhaskar.kumar , Feb 1, 2018 :
    Hi Adam,
    I updated my OP5T to Oreo. But the security patch still shows Dec 2017. Please check the attached screenshot and advise.
  7. rian.acca
    Cupcake Feb 1, 2018
    same here
  8. G_ashok_balu_cvMD
    Cupcake Feb 1, 2018
  9. sunilkumargoudkalli
    Froyo Feb 1, 2018
    sunilkumargoudkalli , Feb 1, 2018 :
    VPN master download select canda get update
  10. jasonycw
    jasonycw , Feb 1, 2018 :
    Caught up with the progress of one from OnePlus 3.
    Still lots of design change that I dislike.
    Removed expandable quick setting, accent color incorrect, old setting menu
  11. G_Anush_o_yADC
    Eclair Feb 1, 2018
    G_Anush_o_yADC , Feb 1, 2018 :
    Hello Team ,
    Thanks for the updateI but i don' see gestures which were given in Open beta3 update, also no camera update my battery is also draining faster!! anyone facing same issue?
  12. Kus82
    Froyo Feb 1, 2018
    Kus82 , Feb 1, 2018 :
    Factory reset aftr OTA??? No way. Dats idiotic. Erase cache, done.
  13. the_derek
    the_derek , Feb 1, 2018 :
    I can't stand the new quick settings. I loved the "mini window" or "mini menu" of the 4-series OS. I do not like having to long press on each icon to make quick adjustments like connect to WiFi or disconnect from a bluetooth device.
  14. Nikhilesh_Kumar
    Eclair Feb 1, 2018
    Nikhilesh_Kumar , Feb 1, 2018 :
    No. it won't.
  15. Nikhilesh_Kumar
    Eclair Feb 1, 2018
    please don't switch network from wifi to data or data to wifi.
    i think you need to download again
    G_Hamid_Khan likes this.
  16. _Akshay_Ms_
  17. polisettysd
    1) Go to Play Store
    2) download an app named Oxygen Updater (Oxygen is the OS of OnePlus)
    3) Open the app and download the update patch. (this is a major update so it will take a very long time about 45minutes May be depending on the speed of the net)
    4) go to the system update in the phone settings
    5) click on the three dot menu and click on local upgrade, the phone shud automatically identify the patch file u have downloaded and after u approve it will install the patch. (this will take some time)
  18. R1517460354696
    Cupcake Feb 1, 2018
  19. MeowArf
    Donut Feb 1, 2018
    MeowArf , Feb 1, 2018 :
    Notifications Menu
    The small notifications menu (half swipe down) would show date/time AND pending alarm for the next day.
    Now after the update, it only shows date/time, what gives?
  20. wdyublwme
    Cupcake Feb 1, 2018
