180
OxygenOS 5.0.4 OTA for the OnePlus 3 & 3T
  1. T1533176195810
    Cupcake Aug 2, 2018
    Contin Maurizio_IT likes this.
  2. BeingIncog
    Nougat Aug 2, 2018
    Contin Maurizio_IT and Sun90 like this.
  3. G_Ketan_Maniyar_NoLX
    Eclair Aug 2, 2018
  4. mage115
    Froyo Aug 2, 2018
  5. F_Tarun_Goud_RSda
    Eclair Aug 2, 2018
    F_Tarun_Goud_RSda , Aug 2, 2018 :
    by "normal way" I meant updating it through the update I got
  6. haseoxth
    Ice Cream Sandwich Aug 2, 2018
    haseoxth , Aug 2, 2018 :
    if you are using beta version then you won't receive stable update. if you don't have root only way to update to 5.0.4 is to clean install full zip pack in recovery mode.
  7. ghostofcain
    Marshmallow Aug 2, 2018
    ghostofcain , Aug 2, 2018 :
    Sorry was only seeing half the convo, if you are a beta user instructions on how to migrate are in the OP of the beta thread, where incidentally they have been since the inception of the beta program.
  8. ghostofcain
  9. Auristic
    KitKat Aug 2, 2018
    Auristic , Aug 2, 2018 :
    Donut downgrade to Cupcake requested! ;)
  10. RASTAVIPER
    Jelly Bean Aug 2, 2018
    RASTAVIPER , Aug 2, 2018 :
    Not really.
    Getting 5-6 hours of SOT as before.
    Probably your device is problematic.
  11. SanthoshGurram
    Honeycomb Aug 2, 2018
    SanthoshGurram , Aug 2, 2018 :
    After updating to 5.0.4 I have noticed heating issue. My mobile is hearing ebenon normal use. Didn't had this before.
    Any suggestions?
  12. youbi
    Portuguese POC Assistant Head Moderator Aug 2, 2018
    youbi , Aug 2, 2018 :
    Threads merged, better discuss the official update on its official thread. ;)
  13. dukenhu
    Cupcake Aug 2, 2018
    dukenhu , Aug 2, 2018 :
    I'm having this same issue. I've tried changing the battery optimization settings but it didn't work. Also a lot of apps that used to work fine are now slower - Facebook Messenger, Camera, Reddit, etc.
  14. ghostofcain
    Did you do a clean or dirty flash of the update? If you dirty flashed it, try a factory reset , after of course backing up your important stuff.
  15. dukenhu
    Cupcake Aug 2, 2018
    I did not flash it but got the OTA update? Sorry I'm not very familiar with flashing so I'm not sure if we're referring to the same thing. Maybe I should try a factory reset though.
  16. ghostofcain
    That's is what I'd do.
    Sun90 and Bobbie63 like this.
  17. Deactivated User
    Aug 2, 2018
  18. Eeshan_Bhave
    Froyo Aug 2, 2018
    Eeshan_Bhave , Aug 2, 2018 :
    I switched yesterday and i realised how much i missed the small features of Beta i had so gotten used to. esp tapping on blank screen for locking. the battery usage remains the same so unless you really are concerned for security update, my suggestion (for those who haven't made the switch) is don't :)
  19. Purantak
    Eclair Aug 2, 2018
    Purantak , Aug 2, 2018 :
    you can clear cache. some times this happens after update.
  20. Deactivated User
    Aug 2, 2018
