180
OxygenOS 5.0.4 OTA for the OnePlus 3 & 3T
  1. Purantak
    Eclair Aug 2, 2018
    Purantak , Aug 2, 2018 :
    boot into factory mode and then clear cache.
  2. Bobbie63
    Marshmallow Aug 2, 2018
    Bobbie63 , Aug 2, 2018 :
    Double tap to lock is present, it's in the launcher settings.
    atenaa, Sun90, Fabritrv and 1 other person like this.
  3. info2shail2010
    Ice Cream Sandwich Aug 2, 2018
    info2shail2010 , Aug 2, 2018 :
    Need Help !!
    I accidently removed One plus File manager (Yes I know it's Stupidity).. and I don't want 3rd Party File manager from play store... and also I don't want to download APK from Apkmirror.com or any 3rd party website due to security reason as those akp might be hacked or something like Spy ware... I don't have any friend near me who has one plus .
    How can I Get 100% Genuine File manager With out full erase or factory reset ?
    I tried Dirty flash full zip but it didn't restored oneplus file manager ... what else I can try ?
  4. Deactivated User
    Aug 2, 2018
  5. Purantak
    Eclair Aug 2, 2018
    it will be okay mine too started draining battery after 5.0.3 but after 1 or 2 charge cycle phone calibrates itself.
  6. Purantak
    Eclair Aug 2, 2018
    let it drain to 2 or 3 % and then charge it to 100 %
  7. G_Antal_Kabatek_ibVE
    Froyo Aug 2, 2018
    G_Antal_Kabatek_ibVE , Aug 2, 2018 :
    Update your launcher. Double tap to lock is available in stable version.
  8. Coglin
    Cupcake Aug 2, 2018
    Coglin , Aug 2, 2018 :
    However, I've uploaded the 5.0.4 firmware.
    I have changed the firmware 4.1.6 to 5.0.4 without a problem. Well, maybe with one small one.
    I had firmware 4.1.6, TWRP 3.1.1-2, and SuperSu 2.82 on my phone.
    After updating TWRP to version 3.2.2, through TWRP and restarting the phone for recovery mode, the following message appeared in TWRP: Mount Decrypt Data, Enter Password :)
    Fortunately, I was able to upload TWRP 3.1.1-2 back through the application on the phone and everything worked.
    I made the update using the method from here: https://forum.xda-developers.com/oneplus-3t/how-to/official-oxygenos-5-0-1-android-8-0-t3728119
    And so:
    1. I've updated TWRP to Blu-Spark TWRP 8.61.
    2. Reboot to recovery
    3. Wipe Dalvik & Cache
    4. Install Menu> Select OOS Full Rom Zip> Swipe to Flash
    5. Flash the provided SuperSU.
    6. In TWRP, click on reboot and select recovery. It will reboot to TWRP again.
    7. Wipe Dalvik & Cache
    8. Reboot System
    Everything works. I did not have to do a factory reset.
    I do not have any problems with the camera and any application.
    Auristic likes this.
  9. sammerasker
    sammerasker , Aug 2, 2018 :
    1- a dirty flash should've done it, are you rooted and flashed with twrp ? if so in twrp wipe system (only system) and then flash the full zip , this should work.
    2- OnePlus files on APKMirror are uploaded (mostly) by OnePlus itself, so you don't have to worry about hacking and privacy, you just make sure the account that posted the file is the OnePlus account, it's 100% safe.
  10. info2shail2010
    Nop.... Dirty flash didn't do it...
    Everything is Stock....
    stock recovery , Stable oos 5.0.4, Bootloader Locked
    I ll see 2nd Option if I find one plus uploaded file..
    thanks for the help and reply
  11. info2shail2010
    One more thing.. Can I install file manager apk that is for Open beta in which we can manage parallal apps ... I m on oos 5.0.4 ... I tried but it's crashing
  12. Topper_Gas
    Jelly Bean Aug 2, 2018
    Topper_Gas , Aug 2, 2018 :
    Try going into safe mode and see if you still have high battery drain, if not, then it's a rogue app, or apps. GSamBattery app is then probably your best friend, I usually find Google Play Services is the culprit so clear the cache and any updates and then reinstall them. I don't use Facebook which is also a known battery drainer.
  13. C1515485427917
    Cupcake Aug 2, 2018
  14. sammerasker
    This is the account
    https://www.apkmirror.com/apk/oneplus-ltd/
    And i think you can of you know the version number , download it.
    Sadly can't help on that, i dontI ise the file manager , o actually uninstall it right away, i use root explorer .
  15. Deactivated User
    Aug 2, 2018
  16. VaibhavBhargava
    Lollipop Aug 2, 2018
  17. VaibhavBhargava
    Sam Nakamura, Auristic and Sun90 like this.
  18. Fabritrv
    Fabritrv , Aug 2, 2018 :
    I'm pretty sure that the version from this build isn't available on apkmirror yet.
  19. Deactivated User
    Aug 2, 2018
  20. VaibhavBhargava
    VaibhavBhargava , Aug 2, 2018 :
    The lastest build is dated 20th July, pretty close to the date of release of this build.
