180
OxygenOS 5.0.4 OTA for the OnePlus 3 & 3T
  1. sammerasker
    Ice Cream Sandwich Jul 19, 2018
    sammerasker , Jul 19, 2018 :
    it's not a downgrade, it has newer security patch and bug fixes,
    that said you can stay at beta, it was stable .
    it appears that way, maybe they're not able to grab a 3T link yet... maybe a little longer.
    Bobbie63 likes this.
  2. Android450
    Marshmallow Jul 19, 2018
    Android450 , Jul 19, 2018 :
    Did you flash first before wiping internal storage?
  3. sammerasker
    i actually backed everything to the desktop then wiped and rebooted back to TWRP then moved the recovery to storage and flashed it...
    but your way is easier for people , you're right... i edited the post to reflect that.
    Bobbie63 and Android450 like this.
  4. G_dhaval_shinde_ZupO
    Froyo Jul 19, 2018
  5. tmlslvnk
    Froyo Jul 19, 2018
    tmlslvnk , Jul 19, 2018 :
    Already mentioned due to spelling in first point in update
  6. G_Kaifi_Ansari_Nvjk
    Cupcake Jul 19, 2018
    G_Kaifi_Ansari_Nvjk , Jul 19, 2018 :
    i downloaded the oxygen os 5.0.4 but it is not installed and security patch is also old version while the update log shows the latest version of oxygen os how i can fix it.please help
  7. Android450
    Can anyone confirm if we still maintain the "improved front camera quality" if we install a newer version of the camera app?
  8. Febin94
    Febin94 , Jul 19, 2018 :
    Is the battery issue addressed in this update .....I find no mention about it
  9. Saikumar7
    Saikumar7 , Jul 19, 2018 :
    Android450
    Did you flash first before wiping internal storage?​
    dirty flash the build by local upgrade and after device turns on ....just go to recovery and wipe data...!!
  10. Febin94
    Only the logs might have got updated ....check all the improvements the log file in other section might not have been updated
  11. Saikumar7
    sooo are you planning to upgrade stable?
  12. Android450
    Thinking about it :p
    Fabritrv, NeVeR_SeTTLe and Bobbie63 like this.
  13. Saikumar7
    its worthless to do now..!! no major changes done here...!! should wait till next update..!! if you don't have any problem with wiping data.....you are good to go..!!
  14. AcmE85
    AcmE85 , Jul 19, 2018 :
    Had no issues with dirty flashing from the Open Beta.
    Front camera quality is as bad as it was before in my opinion.
    Im probably just spoiled from using HDR+.
    Fabritrv, NeVeR_SeTTLe and Android450 like this.
  15. Saikumar7
    soo already upgraded ???
  16. Bobbie63
    Bobbie63 , Jul 19, 2018 :
    Guess we first need to know what the improved camera quality is. :rolleyes:
  17. Bobbie63
    zoestar, NeVeR_SeTTLe and Android450 like this.
  18. Android450
    Hey look on the bright side, you were first this time :D
  19. Bobbie63
    I'm a good swimmer. :p
  20. Sam Nakamura
    sammerasker likes this.
