180
OxygenOS 5.0.4 OTA for the OnePlus 3 & 3T
  1. ghostofcain
    Marshmallow Jul 29, 2018
    ghostofcain , Jul 29, 2018 :
    If your rooted
    Bobbie63 and Starcommander like this.
  2. Prasad Ghadge
    Eclair Jul 29, 2018
  3. RASTAVIPER
    Jelly Bean Jul 29, 2018
  4. ghostofcain
    Ankitbhatian, it was formerly restricted to the beta thread.
    Bobbie63, Android450, LoeKis and 2 others like this.
  5. Milind.Deval
    Gingerbread Jul 29, 2018
    Milind.Deval , Jul 29, 2018 :
    Hope you have installed Oxygen Updater App with correct parameters. If you're not rooted, make sure that 'Update method' is set to 'Incremental update'. Post download, read install guide (which you'll usually automatically see after downloading an update) and follow the instructions. You may also refer App FAQs: https://oxygenupdater.com/faq
  6. G_Rohit_Jadav_mBjh
    Cupcake Jul 29, 2018
  7. Bobbie63
    Nougat Jul 29, 2018
    Bobbie63 , Jul 29, 2018 :
    You could use oneplus switch.
    keithgpowell likes this.
  8. Bobbie63
    Nougat Jul 29, 2018
    Download the app, make a backup, make a copy to the cloud of the backup file. After reset, install switch, copy the backup file from the cloud to your internal storage, start the app and do the rocovery.
    Remember, it won't reinstall the app data, you'll need to back up that seperately
  9. keithgpowell
    Ice Cream Sandwich Jul 29, 2018
    keithgpowell , Jul 29, 2018 :
    Bobbie63
    Remember, it won't reinstall the app data, you'll need to back up that seperately​
    I'm always confused about the meaning of "data" in this context.
    So what is "data" and "app(lication) data" and their differences?
    And how and why to backup "app data " separately?
    And why do people say root is needed to backup some data?
  10. Bobbie63
    Nougat Jul 29, 2018
    That's a very good question still don't understand why it is not possible to make an image from your phone. The switch makes it easier, still a few things are missing.
  11. Bobbie63
    Nougat Jul 29, 2018
    Thing is, due to the fact Android became somewhat kind of a mess, including the updating. I think it's always best to start from zero again. Faults could be imported from apps, copying them would reintroduce the issue. Guess it's up to Google to change that.
    Auristic likes this.
  12. G_The_Little_Minds_Dsnm
  13. RamSurath
    Froyo Jul 29, 2018
    RamSurath , Jul 29, 2018 :
    if i revert from 5.0.4 to 5.0.3 will contacts , applications, settings delete
    or not?
  14. E1508605664693
    E1508605664693 , Jul 29, 2018 :
    I am having some issue of lag with facebook and PUBG, after updating on OS 5.0.4...
    Is there any one having the same issue?
  15. Auristic
    Lollipop Jul 29, 2018
    ghostofcain likes this.
  16. Android450
    Auristic, maortrol and Dresa91 like this.
  17. Skipwoof
    Eclair Jul 29, 2018
    Skipwoof , Jul 29, 2018 :
    Hello,
    Update worked perfectly for me :sunglasses:
    1. TWRP updated to latest "twrp-3.2.2-0-oneplus3.img" recovery.
    2. USB debug enabled + adb reboot bootloader
    3. Cache/Dalvik & Cache wiped via TWRP
    4. Updated to "OnePlus3Oxygen_16_OTA_066_all_1807192301_4444777df49448e7.zip" (From previous stable version) via TWRP.
    5. Installed latest official "SR5-SuperSU-v2.82-SR5-20171001224502.zip" (Just Flashing from TWRP, in order to keep Root privileges after the OOS uptade)
    6. Wiped Cache/Dalvik, via TWRP again
    Reboot... and all seems to work nicely :)
    Good luck for your update guys ;)
  18. MarkyPancake
    Honeycomb Jul 29, 2018
    MarkyPancake , Jul 29, 2018 :
    To cleanly roll back, you'll have to perform a full flash of the older version and this requires a full factory reset to make sure it's done properly.
  19. Centaurus
    Froyo Jul 30, 2018
    Centaurus , Jul 30, 2018 :
    Still can't reject a call with a SMS if the message app isn't the stock one. It used to work before latest update (not this one). :(
  20. sammerasker
    Ice Cream Sandwich Jul 30, 2018
    sammerasker , Jul 30, 2018 :
    Ok about the battery life in this release, the following just happened to me.
    i started a Skype Call at 9:30 pm , at 2:21 am the phone vibrated and the call was cut off and the screen in small red text said low battery (with something about too low the device has to shutdown) , and yes the call lasted near 4:30 min and the screen was on the whole time... i started the call at 83% battery.
    so, take the story the way you like ;)
    Added screen
    Android450 likes this.
