280
OxygenOS 5.0.4 OTA for the OnePlus 5T
  1. Kunjantrivedi
    Cupcake Mar 3, 2018
    Kunjantrivedi , Mar 3, 2018 :
    I update it..then also problem of silent mode is continuing...can't get back on ring mode..
  2. Deactivated User
    Mar 3, 2018
  3. A1508356595709
    Cupcake Mar 3, 2018
  4. simonone
    Honeycomb Mar 3, 2018
    simonone , Mar 3, 2018 :
    It doesn't state that your data will be wiped. Just gives you a precautionary message to backup because bootloader is unlocked. Full ROM download always needed when unlocked and/or rooted. You should be fine. I've just updated like this, with no problem at all. I assume you are not rooted (if you are, you need to reflash Magisk etc after the flash, or you will lose root)
  5. Rockerpai
    Froyo Mar 3, 2018
    Rockerpai , Mar 3, 2018 :
    Thanks for the help. Appreciated.
  6. TheRealGamer
    Lollipop Mar 3, 2018
  7. Robel_Tesfaye
    Cupcake Mar 3, 2018
    Robel_Tesfaye , Mar 3, 2018 :
    When I updated to 5.0.3 apps started crashing and some getting stuck. Today the finger print scanner & facial recognition didn't recognize me. I hope you guys have a solution for that in the updates.
  8. mark.aranha
    Donut Mar 3, 2018
    mark.aranha , Mar 3, 2018 :
    yeah I'm going to wait for this before I install any update. the phone's working fine for me and I don't need the mentioned fixes.
  9. G_Bharat_Prabhas_NjsN
    Gingerbread Mar 3, 2018
    G_Bharat_Prabhas_NjsN , Mar 3, 2018 :
    well said just conveyed what everyone want in their upcoming update and a little battery improvement would have been better the question is when will be the next update cause the patch update is expired and we need some more accent colours and hide navigation bar system like i phone x..... [e]1f44d[/e]
    mark.aranha likes this.
  10. T1519797045224
    Cupcake Mar 3, 2018
  11. idkwhoiam322
    Nougat Mar 3, 2018
    idkwhoiam322 , Mar 3, 2018 :
    Data won't be wiped if you dirty flash, but you have to flash the FULL ROM.
    5star02707, Sun90 and Rockerpai like this.
  12. Shaggy2996
    Cupcake Mar 3, 2018
    Shaggy2996 , Mar 3, 2018 :
    Hey after the oreo update, battery is draining very Quickly... try to fix it out.. or give me other alternetives to save my battery...
  13. Sun90
    Starting Point Expert Community Expert Mar 3, 2018
    Sun90 , Mar 3, 2018 :
    Perform a cache wipe in recovery mode and see.
  14. Shaggy2996
    Cupcake Mar 3, 2018
    i did it too... i clear cache every 3 days... its less than 2 months i have bought this device & facing this issue after oreo update
  15. Sun90
    Do backup all important data and perform a factory reset.
  16. shyamsa
    Cupcake Mar 3, 2018
  17. Shaggy2996
    Cupcake Mar 3, 2018
    okay... will try... thanks...
  18. chandan_choudhary
    Eclair Mar 3, 2018
  19. Shaggy2996
    Cupcake Mar 3, 2018
    checked.... didn't get it yet
  20. Artemus.
    Community Hero 2020 Mar 3, 2018
    Artemus. , Mar 3, 2018 :
    From what I understand, they scrapped the gesture-based navigation in the stable build. You'll have to either stick with the beta channel or use a third-party app like All in one Gestures. Personally, I don't like this way of navigating but to each your own.
