280
OxygenOS 5.0.4 OTA for the OnePlus 5T
  1. Paccman
    Froyo Mar 3, 2018
    Paccman , Mar 3, 2018 :
    Start navigation in Maps. Launch another app, PiP should work with map app in the bottom right hand corner
  2. Kimesik
    Eclair Mar 3, 2018
    Kimesik , Mar 3, 2018 :
    Did the sound quality/volume got crippled in this update like it did in previous Oreo update? I'm interested mostly in Bluetooth audio. Some people complaint that volume is much lower now.
  3. G_Costin_O_oHpX
    Gingerbread Mar 3, 2018
    G_Costin_O_oHpX , Mar 3, 2018 :
    I'm getting also lower volume after update. Must be something to protect your ears from high volume :)
    Kimesik likes this.
  4. Kimesik
    Eclair Mar 3, 2018
    by cable or by Bluetooth?
  5. O1519519028065
    Cupcake Mar 3, 2018
    O1519519028065 , Mar 3, 2018 :
    Should i go for Orea update on my Oneplus 5t ????....took it a week before don't want to deal with bugs...hangs.... battery drain problems
  6. Artemus.
    Nougat Mar 3, 2018
  7. Sachindra Kshetrimayum
    Froyo Mar 3, 2018
  8. O1519519028065
    Cupcake Mar 3, 2018
  9. Sachindra Kshetrimayum
    Froyo Mar 3, 2018
  10. O1519519028065
    Cupcake Mar 3, 2018
    oh ok ty i will post my updated after Samsung s9 lunch .... that's when Android will clear all the bugs
  11. Its.Leandroo
    The Lab - OnePlus 6 Reviewer Mar 3, 2018
    Its.Leandroo , Mar 3, 2018 :
    Android doesn't clear any bugs. It's either Google or OnePlus.
    Also, I haven't faced any problem at all. no battery drain, no crashes, no stuttering, it just works great
    G_Mr_.... and O1519519028065 like this.
  12. Artemus.
    Nougat Mar 3, 2018
    Artemus. , Mar 3, 2018 :
    Just for the record, battery drain is usually due to poor network strength or rogue apps such as Instagram and sometimes Facebook. Sure, there can be SOME issues popping up but they're usually fixed within a few weeks. :)
    G_Mr_.... and Hydra Bob like this.
  13. Catalin_Buzescu
    Jelly Bean Mar 3, 2018
    Catalin_Buzescu , Mar 3, 2018 :
    Awwww, good old Orea... You should skip that and go with Oreo. But I heard Orio is a good alternative also... Don't forget to clear cache after update so we can prevent more pointless threads like this popping up!
  14. Jaywiseman
    Honeycomb Mar 3, 2018
    Jaywiseman , Mar 3, 2018 :
    seem to be getting high usage from android OS and standby since 5.0.4 update. I have cleared cache a few times.
  15. GerardOByrne
    Cupcake Mar 3, 2018
    GerardOByrne , Mar 3, 2018 :
    Cool. delighted with my one plus 5t. love the dash charge. love the fingerprint reader. thumbs up!
  16. G_Costin_O_oHpX
  17. Kimesik
    Eclair Mar 3, 2018
    G_Costin_O_oHpX likes this.
  18. G_Mario_Fitzpatrick_XUNZ
    G_Mario_Fitzpatrick_XUNZ , Mar 3, 2018 :
    Wait... does the Audio Tuner not work with Bluetooth headsets anymore? Did OnePlus purposely stop it? I was listening to a song then I noticed it sounded less bassy than I remembered than I checked the audio tuner and realised it was still greyed out for some reason. I cleared the cache and it still behaved the same.
  19. Artemus.
    Nougat Mar 3, 2018
    Try a third-party equalizer app. Plenty of 'em out there.
  20. G_Mario_Fitzpatrick_XUNZ
    Kytharsis
    I hear you but I can't just skip past the fact that a feature I usually use stopped working. Can you give it a try and see if yours works with Bluetooth? thanks
