280
OxygenOS 5.0.4 OTA for the OnePlus 5T
  1. yash.tivrekar
    Cupcake Mar 4, 2018
    yash.tivrekar , Mar 4, 2018 :
    i bought a new one plus 5t from amazon, it came with stock android nougat (4.7.6 oxygen os), used it for like 2 days, gave me excellent battery. when i got connected to wifi, i got a system msg saying that new android Oreo (5.0.4 update is available). i upgraded to that version. hours after upgrading, i started to notice that there are battery drains faster than before. what is the problem and what should i do now?. i asked for amazon replacement. but for that they went through their online checking system, an app that checks your phone online. they told me that there are no problems with the battery. they are not willing to give me a replacement because of this. what to do guys? please tell me
  2. Constantinos Hadjicostas
    Froyo Mar 4, 2018
    Constantinos Hadjicostas , Mar 4, 2018 :
    why OnePlus does not support the phone probably??
    and the update is comming so slowly. I remember when i had Oneplus 2 it was perfect support and update, with future
  3. MrTalon
    Ice Cream Sandwich Mar 4, 2018
    MrTalon , Mar 4, 2018 :
    I don't know man. they had Chinese New year. that's why, it comes very late.
  4. Varun9266
    Eclair Mar 4, 2018
    Varun9266 , Mar 4, 2018 :
    OxygenOS is good but due to the Oreo update the OnePlus 5t has lost its Equalizer setting for Bluetooth. Like in Noughat version we were able to customise Equalizer through both 3.5 mm jack & Bluetooth devices while the Oreo version do not support Equalizer customisation through Bluetooth.I like to have that feature back.Please find the solution for this.Waiting for your reply
  5. moggers
    Eclair Mar 4, 2018
    moggers , Mar 4, 2018 :
    update just now. all good so far but I didn't experience any of the issues that it was reported to fix. makes me nervous about updating tbh!
    one think I have noticed is that I don't have control as much as I did on which SIM card I am using for 4g (or 3g) data. both are UK Sims and there used to be a simple switch .
  6. SYED REHAN JABBAR
    Cupcake Mar 4, 2018
  7. MLConian
    Donut Mar 4, 2018
    MLConian , Mar 4, 2018 :
    That's weird - Oreo comes with a fast toggle in the quick menu for that specific function (switching data SIM). It was definitely there when I updated to 5.0.3. They took it out in 5.0.4?
  8. Varun9266
    Eclair Mar 4, 2018
    My question is -when will be the audio tuner gets enabled for Bluetooth in Oreo
  9. MLConian
    Donut Mar 4, 2018
    Don't worry, just look up the Super Unbrick Guide on these community pages and flash it back to 4.7.6. It won't affect your warrantee and you'll have your battery functioning perfectly once more.
  10. moggers
    Eclair Mar 4, 2018
    well actually I didn't see it since Oreo update. here are pictures from my drop down menu.
    1. when you pull down. shows mobile data but doesn't indicate which SIM is using what.
    2. soft press on it and it just turns off data or turns off.
    3. long press it and it opens settings.
  11. W1520074249814
    Donut Mar 4, 2018
  12. MLConian
    Donut Mar 4, 2018
    The toggle is now on the second page of those quick settings - notice the white circles at the bottom? You can adjust the layout of the menu and have them on the first page though.
    moggers and smart_tech like this.
  13. smart_tech
    Donut Mar 4, 2018
    moggers likes this.
  14. S1518259756686
    Cupcake Mar 4, 2018
    S1518259756686 , Mar 4, 2018 :
    how to find if one + 5t lost so plz give some instructions becoze our phone nearly 4000 thousand
  15. moggers
    Eclair Mar 4, 2018
    actually it was in my edit of unused 'apps' (like the gamer do not disturb option).....it must have (re) appeared on an update but not checked since.
    anyway all sorted now. cheers!! [e]1f44d[/e]
    MLConian and smart_tech like this.
  16. bibin jacob
    Donut Mar 4, 2018
  17. shan6106
    Cupcake Mar 4, 2018
    shan6106 , Mar 4, 2018 :
    This update is shit.....It solves one problem and new one arrives as soon as you update to 5.0.4 .
    After updating to 5.0.4, even some of the contacts which are already stored in the contact book appears as new unknown number when they call as their name is not getting displayed, jus' their contact number gets displayed.
    PS: How can a company like One Plus gets to release buggy software updates that too in a row (since 5.0.0 to 5.0.4 and also that NetFlix HD encryption key thing)
    I really question, how technically sound your s/w team is.
    Hard to say, but how would you recommend OP devices to your friends if you yourself are not satisfied at first.
    Plz solve this bug ASAP OnePlus
  18. aadarshmittal
    Froyo Mar 4, 2018
    aadarshmittal , Mar 4, 2018 :
    heating issue after using camera for 10 minutes device heats a lot please help if any one facing the same issue
  19. LIJINRAJ
    Donut Mar 4, 2018
    LIJINRAJ , Mar 4, 2018 :
    latest oxygen os 5.0.4 update failure
    it shows signature verification failed
  20. aakashsood
    Jelly Bean Mar 4, 2018
    aakashsood , Mar 4, 2018 :
    File explorer > Show hidden files > . OTA folder > Delete the files in it and download again over a stable network.
