180
OxygenOS 5.0.5 OTA for the OnePlus 3 & 3T
  1. V1535550777675
    Cupcake Sep 11, 2018
    V1535550777675 , Sep 11, 2018 :
    I can't record videos with the front camera , it tells me low memory even tho I have more that 80gb free space , and the rear camera doesn't work at all , I don't think this is a hardware problem , everything was fine before the last update .
  2. ghostofcain
    Marshmallow Sep 11, 2018
    ghostofcain , Sep 11, 2018 :
    Fair enough, a roll back to previous software will fix it then.
    Sun90 likes this.
  3. V1535550777675
    can you please show me how to do it ?
  4. ghostofcain
    Sun90 likes this.
  5. V1535550777675
  6. dimovkster
    Gingerbread Sep 11, 2018
    dimovkster , Sep 11, 2018 :
    does anyone know if they are still changing camera modules for free and if you loose all your data on the phone if you do that?
  7. ghostofcain
    I believe so, and no you shouldn't but best make sure your backup is up-to-date first.
    Sun90 likes this.
  8. dimovkster
    do you know where can I check where's the nearest service center? (I'm in the Netherlands)
  9. ghostofcain
    I believe you need to arrange an RMA via customer service.
    Sun90 likes this.
  10. cobray1
    Donut Sep 11, 2018
    cobray1 , Sep 11, 2018 :
    Had a lower SOT with this update which I found to do with net.oneplus.odm Had to us a magisk zip to remove it.
  11. RASTAVIPER
    Jelly Bean Sep 11, 2018
    RASTAVIPER , Sep 11, 2018 :
    Start with a factory reset first.
    But take a backup before.
    Sun90 likes this.
  12. BebeMischa
    Froyo Sep 11, 2018
    BebeMischa , Sep 11, 2018 :
    The service centre is in Poland. You have to send your device there after opening an RMA. In my case the phone was returned in 8 days fixed free of charge...
  13. Rama gangadhar
    Donut Sep 11, 2018
  14. soulphoenix
    soulphoenix , Sep 11, 2018 :
    How can you squeez out so much. I pretty much max out at 4.
  15. lkosova
    Ice Cream Sandwich Sep 12, 2018
    lkosova , Sep 12, 2018 :
    So I brought my phone to a local phone shop in Chicago They fix a lot of One Plus 3 etc. The speaker being low or going in and out is a hardware issue. It is that the speaker contacts are not making contact and lifting up. Most likely from a drop Within one hour my phone was fixed and now working great... Like I can hear people again. Same for my charging port Small adjustment and no more cord just slipping out!!! So go to a service center and let them fix it. Almost did it myself but then it would of taken like 10 hours hours . Haha
    Auristic and ghostofcain like this.
  16. lkosova
    Low volume on call solved :
    If the call volume is low rule out a few thing first :
    1. Clean with toothbrush. It works for very few people
    2. Turn on your phone speaker .. You should be able to hear the person just fine
    3. When trying to hear press the ear piece against your head a hit harder. This is hit or miss but should be a bit louder.
    4. Your caller Can Hear you just fine.
    Yes. I THOUGHT this was related to an update also.. My calls were like in and out, very low and like crackling so it all makes sense now
    It is a hardware issue!!
    It is the contacts of the ear piece speaker lifting up . Most likely from a drop. Just had mine fixed yesterday and now the phone is great again.
  17. Fabritrv
    Ice Cream Sandwich Sep 13, 2018
    Fabritrv , Sep 13, 2018 :
    Don't know where to post this and creating a new thread would have been too much, but I received the update for the weather app and now this is finally a functional weather app, that displays a lot more informations than it used to. Well done OnePlus, if you gotta have your own apps it's only right ti improve them as much as you can.
  18. T1521678155981
    Donut Sep 13, 2018
    T1521678155981 , Sep 13, 2018 :
    weast update 5.0.5 mobile poor performance don't update [e]1f620[/e][e]1f620[/e][e]1f620[/e][e]1f620[/e][e]1f620[/e]
  19. ghostofcain
    Marshmallow Sep 13, 2018
    ghostofcain , Sep 13, 2018 :
    Had you bothered to read the thread ,instead of just posting, you'd see many users disagree with you, but hey ho that's life.
    Auristic likes this.
  20. kpoyser
    Gingerbread Sep 13, 2018
    kpoyser , Sep 13, 2018 :
    perhaps most may disagree but you cannot dismiss the fact that many others, like myself are also having serious latency issues since this update.
    I've had my 3t since launch and there have only ever been 2 times that I had issues because of an update. Once there was battery drain for a month before it stabilized and now this update, 5.0.5, which is causing my phone to crawl. taps tame more than a second to register, finger print reader takes 2 seconds. Just because you and others don't have these issues after the update does not mean they don't exist.
    I wish all the persons who don't have issues would just SHUT UP when owners voice their legitimate concerns. If you have nothing positive or constructive to off keep your negativity to yourselves!!
