220
OxygenOS 5.0.6 OTA for the OnePlus 3 & 3T
  1. ajmms1999
    Honeycomb Oct 2, 2018
  2. Harry_Broom
    Froyo Oct 2, 2018
    Harry_Broom , Oct 2, 2018 :
    I've been critical of OnePlus in the past, but these recent updates & the promise of Pie later this year has restored my faith in the brand. Congratulations and thanks.
    Sach716 and Kunlan like this.
  3. G_Abhishek_Pandey_RJeM
    Eclair Oct 2, 2018
  4. dcop7
    dcop7 , Oct 2, 2018 :
    Just wait a week or so!
    Why people don't read? Why they just complain complain and complain a bit more?
    Those that have so call battery problems after updating wait a week before complaining
    ofh, jnsson and OzGreat like this.
  5. OzGreat
    Donut Oct 2, 2018
    OzGreat , Oct 2, 2018 :
    Please Clear cache and data from the recovery menu. mine is doing great after the update.
  6. OzGreat
    Donut Oct 2, 2018
    Please Clear data and cache from recovery menu and regarding double tap to wake you need to enable it from gestures. Hope this helps
  7. rkes608
    Cupcake Oct 2, 2018
    rkes608 , Oct 2, 2018 :
    I updated my one plus 3t and it's battery draining much faster I'm regretting for updating​
    It really depends on your usage which is what I have seen.
    With heavy use on snapchat and face book, etc and just not putting it down or to sleep/lock screen I get 6 hrs (sometimes with music and bt on aswell) which I find is really good especially with dash/rapid charge as I'll charge it at around 12/1pm and that'll last me the rest of the day til I get home... Sometimes needing a top up before I leave work.
    I tend to get 6-8 hr plus with WiFi or data on not much use just when I need to send messages etc.
    Again with what people are saying give it a week...
    Might be worth giving a screen shot of battery usage and seeing how it compares but ultimately it depends on how you use the phone.
    Ultimately what I would recommend is just get a battery bank it makes life alot easier when your out and about.
  8. G_nakul7
    Cupcake Oct 2, 2018
    G_nakul7 , Oct 2, 2018 :
    sorry to say. i tried for double tap to wake . but it is not workinh and not any other gesture working.
    Main question is.
    how to get back to stock rom and recovery.when i am on custom rom .
    just flash stock rom.via twrp and flash stock rec. later.
    OR
    i have to flash firmware file.?
  9. G_Blue_Vite_fuNN
    Froyo Oct 2, 2018
    G_Blue_Vite_fuNN , Oct 2, 2018 :
    for me it was about 360mb i think. don't really Remember.
  10. Mohan Thiru
    Eclair Oct 2, 2018
  11. Xypleth7
    Xypleth7 , Oct 2, 2018 :
    My phone drained to 0% from 50% over night. Missed my alarms, great.
    Yes, I cleared the f********** cache after it f************ my day.
    I'm done OnePlus, such an aggressive app management, basically Apps you want to be running in the background get killed, and still battery drains. You're doing something very wrong.
    santhosh311983 and G_nakul7 like this.
  12. santhosh311983
    santhosh311983 , Oct 2, 2018 :
    battery life seems to be much better then before ..getting 5+ hrs of SOT ..Attached the stats
    from 40 ~ 1 % will get more 2.5 hrs of SOT .. irrespective of WIFI or Mobile data !!
  13. rkes608
    Cupcake Oct 2, 2018
    Do you use you device alot, i only get 6 hrs loads of use during the day and 8 hr + minimal use.
    Just wanna see if you do anything that may improve my battery life is all.
    Thanks
  14. B1538477242274
    Cupcake Oct 2, 2018
  15. santhosh311983
    I cannot say if I use my device a lot or not ..but I usually get 5+ hrs of SOT and over 20+ hrs of standby ..so I belong to mixed user catagory ..but considering the age of the device and the apps which I use ..I am happy with the battery life ..
    btw I use "GREENIFY" app a lot ..this will hibernate unwanted background services ..it's helping a lot ..
  16. rkes608
    Cupcake Oct 2, 2018
    Thanks I'll look into the app!
    And yeah I am happy with the battery life too just want to try and do what I can to extend it a bit more but it seems we get around the same which is good for a 2 Yr old device.
    Thanks!
  17. santhosh311983
    yes bro ..and if you are even more concerned to perform R&D
    then get your device rooted and install TWRP , SUPERSU and then install "GREENIFY" ..
    or
    Try custom ROMs ..plenty of them available for OP3 & 3T ..with "FRANCO" kernel ..sure you will achieve legendary SOT & cell standby ..I will be performing this after 2 months from now !! :)
    rkes608 likes this.
  18. .Deleted_Member.
    Nougat Oct 2, 2018
    .Deleted_Member. , Oct 2, 2018 :
    jnsson likes this.
  19. vinay_thakur16
    Cupcake Oct 2, 2018
  20. .Deleted_Member.
    Nougat Oct 2, 2018
    which service providers???
