212
OxygenOS 5.0.8(HotFix) OTA for the OnePlus 3 & 3T
  1. Ankitbhat12345
    Jelly Bean Mar 19, 2019
    G_Chinmay_bapat_oQMj likes this.
  2. G1547104746565
    Cupcake Mar 19, 2019
  3. Auristic
    KitKat Mar 19, 2019
    Auristic , Mar 19, 2019 :
    What is your OS version?
  4. G1547104746565
  5. Auristic
    KitKat Mar 19, 2019
    As the beta is over you have to go back to stable to update to 5.0.8:
    1- Backup your phone
    2- Download 5.0.8 from https://www.oneplus.com/support/softwareupgrade
    3- Factory reset your phone
    4- Install ROM from recovery
    If you don't understand what I'm saying you shouldn't have installed beta in the first place and you'll have to search how to do that since I won't spoonfeed you more.
    As always: do it AT YOUR OWN RISK.
    ghostofcain and mage115 like this.
  6. D1553060678416
    Eclair Mar 20, 2019
    D1553060678416 , Mar 20, 2019 :
    There is chance that the pie update might roll out in beta builds as the are testing the beta builds for the CTS test .
  7. Auristic
    KitKat Mar 20, 2019
    Auristic , Mar 20, 2019 :
    Since OP said the new beta will be based on H2OS instead of OOS I think you'll also have to factory reset to go back to beta...
    You choose...
    ghostofcain likes this.
  8. D1553060678416
    Eclair Mar 20, 2019
    The cts test aren't required for the H2O Os , David said they were running the compatibility test suite for the beta builds which is oxygen os . Don't know he didn't kinda explained it properly but indeed he said he was running the test for beta builds.
  9. 6301995
    Froyo Mar 20, 2019
    6301995 , Mar 20, 2019 :
    CTS is not mandatory for hydrogen os
  10. D1553060678416
    Eclair Mar 20, 2019
    6301995
    CTS is not mandatory for hydrogen os​
    Compatibility test suite shouldn't have taken more time. I don't know why they are prolonging the time. The update is way too delayed !
    Ankitbhat12345 likes this.
  11. runboy93
    Jelly Bean Mar 20, 2019
  12. ghostofcain
    Marshmallow Mar 20, 2019
    ghostofcain , Mar 20, 2019 :
    Your ability to carry out a simple forum search before posting, where?
    I bow to your knowledge of compatibility testing, can you link to the custom ROM you have produced?
    Auristic likes this.
  13. runboy93
    runboy93 , Mar 20, 2019 :
    "Before Pie update", well yeah that is helping xD
  14. ghostofcain
    A simple search, should inform you of OnePlus' policy of not releasing ETAs, so not sure what answer you where expecting?
  15. D1553060678416
    Eclair Mar 20, 2019
    I am new to java programming will provide you a link when I make a costom rom . Just a undergrad student here . go easy on me.[e]1f601[/e].
  16. ghostofcain
    Sorry just assumed with your familiarity with fulfilling CTS requirements that you where a fully fledged developer, maybe getting a ROM CTS ready is harder than you think?
  17. 6301995
    Froyo Mar 21, 2019
    6301995 , Mar 21, 2019 :
    If any problem is encountered in the CTS process, they have to fix it or else they will not get approval from Google.
  18. D1553060678416
    Eclair Mar 21, 2019
    D1553060678416 , Mar 21, 2019 :
    In CTS process the code aren't viewed by Google . CTS test can be done by you too. But let's hope they fix the issue soon
    6301995 likes this.
  19. 6301995
    Froyo Mar 21, 2019
    I am on oos 5.0.6,is oos 5.0.8 stable?
    how is the performance and battery life?
  20. D1553060678416
    Eclair Mar 21, 2019
    it's quiet good to say , I get 4 hrs of sot with normal use.
