212
OxygenOS 5.0.8(HotFix) OTA for the OnePlus 3 & 3T
  1. mikica023
    Honeycomb Apr 28, 2019
    mikica023 , Apr 28, 2019 :
    Go to Oneplus , support, downloads and download 5.0.8. Put to internal storage . Install local or in recovery . It's recommend clean install.
    Dolphingurl and Kunlan like this.
  2. Dolphingurl
    Donut Apr 29, 2019
    Dolphingurl , Apr 29, 2019 :
    ok I'm going to try it now to see if it works.
  3. Dolphingurl
    Donut Apr 29, 2019
    I've tried recovery mode but didn't work..
  4. Dolphingurl
    Donut Apr 29, 2019
    yay I finally got it installed. thank you so much. it took a little bit
  5. ghostofcain
    Marshmallow Apr 29, 2019
    ghostofcain , Apr 29, 2019 :
    Step by step Instructions can be found in the OP of the release thread for your current beta build.
    Dolphingurl likes this.
  6. Dolphingurl
    Donut Apr 30, 2019
    Dolphingurl , Apr 30, 2019 :
    thank you. I got it installed
    ghostofcain likes this.
  7. aathavan.aathu
    Cupcake May 6, 2019
    aathavan.aathu , May 6, 2019 :
    hi friends...i am not getting any system updates...my last updated last year september..i am using oneplus3t
  8. Cervantes
    Lollipop Moderator May 6, 2019
    Cervantes , May 6, 2019 :
    Hi
    This is the last update, Android P is in beta
    Please, read the first post
    You use the topic search instead of opening a new thread
    Thread merged
  9. y.w.a.f
    Cupcake May 8, 2019
    y.w.a.f , May 8, 2019 :
    Is it safe to directly update from 4.5.1 (Android 7.1.1) to 5.0.8?
  10. AanandRoy
    Froyo Aug 6, 2019
    AanandRoy , Aug 6, 2019 :
    gps callibration problem still present,, it went to low always after some time, any help
