212
OxygenOS 5.0.8(HotFix) OTA for the OnePlus 3 & 3T
  1. K1543158258599
    Froyo Dec 14, 2018
  2. sam_G
    Cupcake Dec 14, 2018
    sam_G , Dec 14, 2018 :
    doesn't come across anything new. Seems like an internal or security updates.
  3. K1543158258599
    Froyo Dec 14, 2018
  4. sam_G
    yep,cause I'm updating it using VPN . Im from India and the update is not here yet.
  5. mohd_areeb
    Honeycomb Dec 14, 2018
    mohd_areeb , Dec 14, 2018 :
    Use Tunnel bear, select Germany server and check for update!
    Remember you will only get 500 mb/month on tunner bear.
    So, after checking the update it will show you the new update released! Lock the settings and system update and start downloading the update, and after few secs disconnect the tunnel bear server!
    Roy91 likes this.
  6. mohd_areeb
  7. sauvik.dasmodak
    Eclair Dec 14, 2018
  8. ghostofcain
    Marshmallow Dec 14, 2018
    ghostofcain , Dec 14, 2018 :
    This is a user forum, were as much in the dark as you.
    From techopedia.com
    mohd_areeb likes this.
  9. SandeepChouhan
    SandeepChouhan , Dec 14, 2018 :
    how to update wia Vpn
    any apps to download or
    please explained
  10. sam_G
    download tunnelbear VPN from play store(its free).Set your location to Germany . And go and check for your update.
    SandeepChouhan likes this.
  11. OKiedron
    OKiedron , Dec 14, 2018 :
    Thank you!
  12. Deactivated User
    Dec 14, 2018
  13. Pepsican
    Froyo Dec 14, 2018
    Pepsican , Dec 14, 2018 :
    For those wondering why 5.0.7 has not arrived yet, Oneplus found a bug and made a new version. Hence the delay and the reference to hotfix.
  14. the_o2
    User of the Year 2018 Dec 14, 2018
    the_o2 , Dec 14, 2018 :
    So you are on 5.0.8, then why you searching for 5.0.8 update :confused::confused::confused:
    Btw the update is rolling out in random, soon you get if you are on 5.0.6
    Sun90 likes this.
  15. Deactivated User
    Dec 14, 2018
  16. Dresa91
    User of the Year 2016 Dec 14, 2018
    Dresa91 , Dec 14, 2018 :
    be patient. It is a staged rollout. Not every device is getting the update at the same time. please be patient and wait.
    Sun90 and the_o2 like this.
  17. Deactivated User
    Dec 14, 2018
  18. C1544783500443
    C1544783500443 , Dec 14, 2018 :
    use vpn to download, set to canada region....try to search update again....download, done!
    SIMPLE!
  19. C1544783500443
  20. G_Masoud_rasoolnejad_QDM
    Eclair Dec 14, 2018
